Old 08-09-2012, 12:11 PM   #1
Catch_22
Catch_22's Avatar
Electric Fan Options
I have had it on my list to add an electric fan for some time and remove the stock fan. Some people say it helps with horse power, others say it cools better. Whatever the reason I need a better way to cool things down.
I do not have a shroud right now. I know my cooling suffers from this detail.
After researching myself and being told by others to just zip tie an electric fan on it, I'm torn on the best option.
Will zip tie an electric fan on it work ok with this?
http://www.jegs.com/i/Proform/778/141-646/10002/-1
At 16" its going to get close to that 80% coverage. And its cheep.
Ford Taurus stock fans of "legend" are another option. Has a smaller fan but a built in shroud that gives it close to 80% coverage as well.
Another option I have contemplated was leaving the hand chopper blades of doom and putting in a shroud.
I have also seem people mod an electric fan into the shroud. This cost the most at near $200.
Considering the aftermarket temp gauge I have is correct I run about 160 (in +80F) and up to 180 (in +95F)
Hauling things will make it runaway and overheat. I had to cut it off when helping a friend move on a 101F day.
Cooling is key, but keeping in the $100 range is desired. Any opinions of what would be best? Thank you, as always for any input. You guys rock.
Catch_22 is offline   Reply With Quote
Old 08-09-2012, 12:23 PM   #2
Frijolito1988
Re: Electric Fan Options
Keeping an eye out on this one as I am also considering adding one to my truck.
Frijolito1988 is offline   Reply With Quote
Old 08-09-2012, 12:59 PM   #3
zellway
zellway's Avatar
I understand the want to stay "cheep" on the cost but when you over heat and have to go into repairs the fans will have been a place you would not want to go cheep on. I have the 2 fan kit from Old air products. Its almost $300 but its hard to beat. Bolts into the stock shroud mounts and 2 wires to the battery and one into the fuse block.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 08-09-2012, 01:06 PM   #4
MARKDTN
I would never do a zip-tie fan. The torque when it starts has to be hard on the radiator fins.
For a basically stock truck, I would just get a shroud. To do a decent electric fan you will have to upgrade your alternator. If I was going to do an electric, I would do a dual setup and stage them so that you only run 1 unless it gets really hot. That will cut down on amp draw. If you search the catalogs at the parts stores you can find water temperature switches that will come on at varied temperatures.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 08-09-2012, 01:30 PM   #5
MAK191
I was at the wrecking yard a few weeks ago and picked up a ford windstar dual fan assembly. It seems to fit very well and will be easy to make brackets. The best part was it super cheap ($25). I am doing an LS swap so the dual fans will be computer controlled. You could easily set it up with a switch to turn on the second fan when it gets hot out or you are towing.
MAK191 is offline   Reply With Quote
Old 08-09-2012, 01:39 PM   #6
zellway
zellway's Avatar
WHat year windstar was that off? Looks good.
Erik
Old 08-09-2012, 01:56 PM   #7
Catch_22
Catch_22's Avatar
This is nice, how loud is it?
Old 08-09-2012, 02:08 PM   #8
BlackedOut67shorty
BlackedOut67shorty's Avatar
Ooooo thats really neat, makes me just wanna go down to ez pull and violate a windstar for its fans lol
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 08-09-2012, 04:49 PM   #9
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
We manufacture a fan shroud set up that works well. They are designed for our trucks and come complete with fans, shroud, wiring, thermostat and manual override switch. We have them in standard steel, powder coated steel, stainless steel, pollished stainless steel, and aluminum. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-09-2012, 05:03 PM   #10
zellway
zellway's Avatar
Now that is a clean set up!
Erik
Old 08-09-2012, 05:03 PM   #11
Catch_22
Catch_22's Avatar
Originally Posted by Classic Heartbeat View Post
... and come complete with fans, shroud, wiring, thermostat and manual override switch. .
Found the shrouds, but where is the kit you speak of?
Old 08-09-2012, 09:55 PM   #12
RPBurris
RPBurris's Avatar
I have heard of buying a replacement stock fan assembly for a chevy hhr. They are about $50 from Rockauto and come with a shroud and i beleive all the sensors are built in. Iread about it on another forum for cooler large motors in small bays and they allegedly work great. I know they at least keep my hhr cool. They are also two speed fans.
1969 Chevy K20 Longbed
RPBurris is offline   Reply With Quote
Old 08-09-2012, 10:01 PM   #13
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
http://www.classicheartbeat.com/cata...assemblies.htm
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
