08-09-2012, 09:15 PM | #1 |
1967 Crossmember with Disc Brakes
I hate to ask, but I jut want some confirmation. I've already got all the parts together, my question is about routing the hard lines. Drum brakes mount at the rear of the crossmember, disk at the front. Should I run the disc brake hard line kit to the back where the drum mounting tab is, or to the front and figure a way to mount a tab to hold it? TIA!
Posted via Mobile Device |
08-09-2012, 11:01 PM | #2 |
67-72 parts collector,…
Re: 1967 Crossmember with Disc Brakes
Run it to the back where you already have a tab.
08-09-2012, 11:07 PM | #3 |
Run drum brake hard lines with ece conversion hoses or get disk brake hard lines and hoses?
08-09-2012, 11:11 PM | #4 |
Your choice.
Are you bending new lines or buying them ? I don't think it really matters. Posted via Mobile Device
08-10-2012, 01:42 PM | #5 |
Haven't decided yet. I think I'm going to use a Wilwood manual master, so I'm going to use the factory hardlines and flex line from the master to valve and valve to hardline.
