08-10-2012, 02:06 AM | #1 |
fuel pump!!
i have an 82 chevy custom deluxe 10 and want to install an electric fuel pump.
but idk which one to buy and how to install it? because i want to install a remote starting kit, thanks |
08-10-2012, 06:31 AM | #2 | |
78K & 79C Jimmys
Re: fuel pump!!
for an auto start? still need to pump the gas but most auto starts will keep it running start like norm,push the start,pull the key
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
08-10-2012, 12:05 PM | #3 |
Re: fuel pump!!
even with electric fuel pump?
08-10-2012, 12:24 PM | #4 |
78K & 79C Jimmys
Re: fuel pump!!
The one on the block is always pumping
It's the movement of the pedal that does the squirt Posted via Mobile Device
08-10-2012, 12:34 PM | #5 |
Re: fuel pump!!
Yeah the electric pump will make no difference in starting and running cold. You would still need to follow how you start your truck now. Electric pump does not get gas to the engine, the accelerator pump does and for the accelerator pump to do that you have to pump the gas.
So if your truck now will not start without pumping the gas, the electric pump will make no difference. That said an industry standard tried and true universal pump is the carter. $82 from jegs. http://www.jegs.com/i/Carter/180/P4070/10002/-1
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
08-10-2012, 01:00 PM | #6 |
Re: fuel pump!!
You'll need to go fuel injection for a remote start to work on a cold engine or something that has been sitting for days.
Unless you already have a carbed engine that has been running within a few hours that day, then it should start fine without touching the gas. |
08-10-2012, 08:53 PM | #7 |
Re: fuel pump!!
alright thanks guys!
08-10-2012, 09:06 PM | #8 |
Re: fuel pump!!
my truck starts the first turn of the key
dont have to pump the gas maybe its just my new carb lol |
08-10-2012, 09:09 PM | #9 |
Re: fuel pump!!
my 63 chevy truck does start the first time and it has a new carb with double gas line in the carb
08-10-2012, 09:40 PM | #10 |
Re: fuel pump!!
Couldnt he use a regular gas pump( the one on the block)
and run like a relay or a capacitor on the ignition wire so it can maybe keep it cranking for like 1-4 seconds enough to crank it over |
08-10-2012, 09:48 PM | #11 |
Re: fuel pump!!
Just a thought, but if you used an electric pump, why couldn't you tee into the line with a solenoid and run a line from the solenoid into either a fitting into the intake or into the carb. Kind of like an electric primer. Most remote starts have buttons for locks or trunk that you could use to trigger the solenoid. Hit the start button bump the trunk button, and in theory your truck is running. Would be a little bit of messing around, but should accomplish the goal.
08-10-2012, 11:27 PM | #12 |
Moderator
Re: fuel pump!!
Cycling the gas pedal to the floor closes the choke and sets the throttle stop up on the high idle cam. The gas squirt from the accelerator pump is not really needed.
Use a high idle solenoid that's set high enough to allow the choke linkage to move completely. Kick it on for a few seconds when the remote start is engaged.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
