Old 08-10-2012, 10:13 AM   #1
Breadstick
Aftermarket speedometer on 700R4
I have a 700R4 transmission in my 64 C10 and I'd like to get an aftermarket speedometer in it, since the original doesn't work. How hard is it to hook one up and how do you go about it?
Breadstick is offline   Reply With Quote
Old 08-10-2012, 10:23 AM   #2
hd74
Re: Aftermarket speedometer on 700R4
it depends on year of transmission,early one have cable drive newer ones are electric drive
hd74 is offline   Reply With Quote
Old 08-10-2012, 01:21 PM   #3
doobiebro
doobiebro's Avatar
You can use your existing cable if it is long enough..There are many styles and vendors on gauges to choose from. I went with Bowtie Overdrives and gave them my ring gear ratio on my diff and tire size and order the right speedo gear and speedo adapter on my 700R4 (91)
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 08-10-2012, 01:46 PM   #4
Breadstick
Thanks for the replies. How do I tell when my transmission was made? It was in the truck when I bought it.
Old 08-10-2012, 02:37 PM   #5
doobiebro
doobiebro's Avatar
Here you go...http://www.technicalvideos.com/what_year_700R4.phtml
Old 09-26-2012, 09:17 PM   #6
Breadstick
It looks like I have a post-1992 transmission because it has a cable going into the connector on the passenger side like in the link above (although I don't know what it goes to). I guess it's a refurb because the plate doesn't have anything on it. It has a big "6" on the middle of the passenger side and "MD8" towards the front on the passenger side. It also has 8663548 on the driver's side.
It also has a square four pin connector on the driver's side. Does anyone know what that's for?
Old 09-27-2012, 12:20 PM   #7
luvbowties
luvbowties's Avatar
Thumbs up Re: Aftermarket speedometer on 700R4
Probably leads for lockup convertor solenoid?
sam
luvbowties is offline   Reply With Quote
