Seatbelts for a 72
I just bought a 72 and need to install shoulder belts so my son can ride in it with me. Everywhere i look it sounds like people have complaints about the universal belt kits... anyone had success buying shoulder belts and just bolting them in? Any advice would be awesome!
Re: Seatbelts for a 72
I was looking at these... but they appear to be universal as well... http://www.lmctruck.com/features/cb/cbcbw.htm
![]() Join Date: Sep 2010
Mine were made at Morris Classic Concepts in South Carolina. Great people to do business with. They have many different types and colors. Mine were just what I wanted. http://www.google.com/url?sa=t&rct=j...w7bNuXDx5u1lMA . . . . |
I installed mine on my 68 CST. It was simple. Pull the seat out and everything bolted right in. I'm pretty sure I got it all from Brothers Truck. I like them alot better than the lap belts.
Thanks guys! The Brothers belts look great... so expensive for a guy like me, though! I have to have a shoulder belt... I am 34... never wore seat belts when I was young... had old Chevy after old Chevy, etc... Now? I feel naked without one... plus my son is dying to ride in dad's new yellow truck and he is still in a car seat...I don't want a show truck... just safety and a tough old ride to navigate our needs for a 4x4... I've wanted an old truck back, like this, for years...
i bought the ones from lmc truck and mine work great
Moderator
![]() Join Date: May 2007
www.gemstreetrods.com
this old codger has the best prices going. he sells the same belts as brothers, lmc, etc. check it out. Posted via Mobile Device
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
So are these just a bolt in issue? I was looking for the shoulder bolt hole and don't seem to have one. 70swb. could I just make one? there is a hole in the corners for some 3" speakers. Anyone have the measurements where these should go?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Here's where the standard, threaded hole is ( with it's cap in this picture ) . . . . |
#10 | |
http://67-72chevytrucks.com/vboard/s...9&postcount=13 EDIT > Never mind, beat me to it...
1971 GMC C2500 Custom Camper - Second Owner. 350/TH350, Dana 60 Rear. |
Thanks guys! I will try to install a weld nut back there as my truck does not have this feature..
I bought mine from LMC truck and I like them. I had lap belts before and installed these.
#13 |
Well... what I keep seeing people say is either A.) The buckle stud that mounts to the floor is too short, or B.) The passenger seat belt has to be twisted around, because it is universal, and therefore falls under the seat because the whole buckle will not make it through the seat... as well as things like the shoulder belt won't thread into the factory port at top... etc...
#14 |
I did a write up on my seat belt install. The seat belts bolted up with no problem with no length issues (mind you my fuel tank is no longer mounted in the cab).
I used the same seat belts as used in The rebirth of El Scrocho (only difference is his are for bucket seats and mine are for bench). If you read his post, you'll see he had to relocate the driver's side mount a few inches to clear his cab-mounted fuel tank. These appear to be the same seat belts available from www.gemstreetrods.com.
'72 C20 Custom Camper - SB350/TH350, Daily Driver |
#15 | ||
, or because it is universal, and therefore falls under the seat because the whole buckle will not make it through the seat... as well as things like the shoulder belt won't thread into the factory port at top... etc...[/QUOTE]
I have a thread on here with my install as well. Quote:
-B |
#16 |
Oh and the 3-point kits I bought had the bolt already in the bracket to be bolted into the 'B' pillar and went in without any issues.
#17 |
That's awesome to hear... my tank is in cab... (I am not NEAR addressing that!)... I am already paying a guy to do my floorboards... I have more love for the trucks than skill to fix 'em... but I can tinker! I will shop from all of these awesome recommendations!
#18 |
i took mine out of a 1973 c10.. worked fine
#19 |
Cruzin
I installed some in my wife's truck from http://www.seatbeltplanet.com/ these are the non-retractable ones retractable is available in tons of colors. Bolted right in.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#20 |
I have looked for a 67-72 with the optional belts... (fat chance, i know)... but the difference will be the tank in cab... unless you have the same? It should change where the retractor goes... If you bolted them right in, I am interested, though! I can find a 73 and up anywhere...
