Old 08-10-2012, 07:19 PM   #1
cmyc5575
flip kit question for 4/6 drop???
ok i bought my kit for my 4/6 drop and the question i am wanting to know do i have to c- notch the frame or can i just cut the orginal bump stomp and put the smaller ones in when i go to do the flip? thanks guys
cmyc5575 is offline   Reply With Quote
Old 08-10-2012, 07:50 PM   #2
J Knight
J Knight's Avatar
Re: flip kit question for 4/6 drop???
If you install flip bracket only, then just cut out the bumpstop, if you add drop shackles or remove leafs then yes c-notch it.
You need a BARE MINIMUM of 2in of travel between axle and frame. Once your kit is installed and if you have less than 2in....notch it.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 08-10-2012, 07:58 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Most flip kits I've seen only drop 5in
I have a 6/7 drop on mine and dont have to run a c-notch
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 08-10-2012, 07:58 PM   #4
cmyc5575
do you have a pic of the flip bracket?
Old 08-10-2012, 08:05 PM   #5
J Knight
J Knight's Avatar
These are DJM flip brackets and shock extenders. Recently some guys have been having problems with this brand, I installed 2 sets last year with no problems.
John
Old 08-10-2012, 08:10 PM   #6
cmyc5575
yeah i read up on that forum something to do with they should only be used for show not high performance. i think that i might have bought the wrong kit do a 4/6 drop
