Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-10-2012, 09:20 PM   #1
BigDan3131
BigDan3131's Avatar
Question Hood and or Fenders
I figure this is probably the best section to ask this in.
Are any of you using fiberglass hoods or fenders on your trucks instead of replacement sheetmetal. If you love them that's great, then it pushes me towards buying them [fenders] instead of fixing my rusted out ones.
The hood, are they mounted to hinges and using the stock latch or hinges with pins or just pin on only? I need to see pictures of 60-66 trucks with either the hood or fenders. With the hood show me pics of where you mounted the hood pins.
TY
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-11-2012, 12:11 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Hood and or Fenders
I'm using the US bodysource 'street grade' fiberglass hood and front fenders. It's HEAVY,, probably no weight savings over steel, but no rust.
http://www.small-block-chevy.com/round1.jpg
I HATE hood pins. So I 'reversed' pined. Meaning the pins are part of the hood, and stick down through the inner fender and pin is inserted up inside the wheelwell.
In this pic you can see the pins being part of the hood, and they go down through the hole the prop rods are in (to hold the heavy hood when up)
http://www.small-block-chevy.com/ima...10/66Oct10.JPG
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 08-11-2012, 02:59 AM   #3
BigDan3131
BigDan3131's Avatar
So having a cowled hood is the only way to get fresh air in since the front openings are closed, correct? Great idea about reversing the pins, makes for a much cleaner and stock type look.
Old 08-11-2012, 09:40 AM   #4
Marv D
Marv D's Avatar
You could open those up, I just prefered not to.
