Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 08-10-2012, 10:26 PM   #1
Hart_Rod
Hart_Rod's Avatar
WTB Blazer middle seat
I'm looking for a blazer middle seat. It must be setup for 2 mounting brackets in the rear, not 4. The measurement between the holes in the mounting brackets is approximately 32.25 inches. Thanks in advance,
Rob
Hart_Rod is offline   Reply With Quote
Old 08-22-2012, 10:25 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: WTB Blazer middle seat
ttt
Old 08-22-2012, 11:34 AM   #3
burb71
Active Member
I may have what you need, its in parts, seat frame bottom and back, foam buns bottom and back, front and rear mounting brackets and arm rests
You will need to get a new cover.
burb71 is offline   Reply With Quote
Old 08-22-2012, 11:40 AM   #4
Hart_Rod
Hart_Rod's Avatar
All I really need is the bottom frame and the rear mounting brackets (may not need those). I have the rest. Let me know.
R/
Old 08-22-2012, 12:00 PM   #5
Classic Bowties
Always on the hunt...
Originally Posted by Hart_Rod View Post
I'm looking for a blazer middle seat. It must be setup for 2 mounting brackets in the rear, not 4. Thanks in advance,
Rob
Rob, you have me on the blazer middle seat part, do you mean burb 2nd row short seat? Below are a few rear seat combo pictures that I had on file, maybe you can pick/point out exactly which type you are after. Mel
Classic Bowties is offline   Reply With Quote
Old 08-22-2012, 01:24 PM   #6
Hart_Rod
Hart_Rod's Avatar
Mel, I think all the burbs have different seats and setups, . I a seat bottom with the bracket setup in picture #11. Clear as mud?
Old 08-23-2012, 03:26 PM   #7
Hart_Rod
Hart_Rod's Avatar
Burb71 - Were you able to find anything?
Mel - do you have an extra seat bottom like the one I pointed out?
I need the rear brackets and the seat bottom.
Old 08-23-2012, 07:59 PM   #8
burb71
Active Member
I know I have em in storage somewhere, no luck finding yet
Old 08-23-2012, 08:03 PM   #9
Hart_Rod
Hart_Rod's Avatar
No big hurry and thanks for looking. Just let me know when you find it.
Rob
Old 09-03-2012, 03:40 PM   #10
Hart_Rod
Hart_Rod's Avatar
Any luck yet?
Old 09-03-2012, 05:27 PM   #11
burb71
Active Member
I have not had time to get back to my storage, all you need is the bottom seat frame and rear mounting brackets right
I will get back there for you, I know I have em
Do you have an original front window gasket and trim from a 1967-70 truck?
I need one for my 68
Old 09-03-2012, 06:37 PM   #12
Hart_Rod
Hart_Rod's Avatar
Thanks. I think I might have the trim, but not the gasket.
Old 10-15-2012, 09:33 PM   #13
Hart_Rod
Hart_Rod's Avatar
Still looking for a seat with brackets that are 32.25" from center of the mounting points. Here's a picture.
Old 11-19-2012, 10:20 AM   #14
Hart_Rod
Hart_Rod's Avatar
Bttt
Old 04-24-2016, 12:29 AM   #15
Hart_Rod
Hart_Rod's Avatar
Mel - I need to of the rear brackets like the top seat in picture 11. Somehow I ended up with 2 of the short brackets and need the taller ones. Let me know if you can help, Thanks Rob
