65 4X4 Disc Brake Conversion
Will the brake booster & master cylinder from a 99 C10 work on a '65 K10? The plan is to convert the 65 to disc brakes by swapping the axle with a 73-87 - would it be best to use the brake booster that goes with the new axle? I have a 99 booster, wondering if I should hang onto it for this project or turn it into cash??
Thanks!
'65 GMC Suburban 4X4, '71 GMC 4X4 LWB - The Yellow Eyed Monster, '86 C10 Silverado - Oldest Daughter's Pickup, '88 S15 GMC Work Truck, '95 GMC SLE 4X4 - Second Daughter's Truck, '99 K1500 GMC Suburban Road Trip Machine, 2000 C2500 W/T Utility Bed Work Truck, '03 Silverado - Wife's Grocery Getter |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 65 4X4 Disc Brake Conversion
I'm not sure about a '99 booster, but the '88-'98 boosters are one of the compatable boosters for my booster brackets. The '99 booster may work also, I just have not had one to try. I would use a '73-'87 master cylinder with that conversion. You do not have to use a '73-'87 booster. There is a link to the for sale thread in my sig line \/ \/ \/
Thanks for the info captainfab! The booster is actually off of a Suburban, so it should be the same as the '88-'98 piece.
