![]() Join Date: Jun 2012
need help on wheel size
so my truck is stock still but i am going to add a 3/5 or 3/5.5 drop. i want it level and low. but i have six lugs. i wanna get some new wheels but know i am going to have to go bigger. i am thinking 18 or 20's. what size of tire on the back can i run?(i want it WIDE like maby drag radials or street/strip) and with what back spacing? same for the front but alot narrower. also does anyone wanna recommend wheels and tires?
Re: need help on wheel size
also what bolt pattern is it?
no one?
Bolt pattern is 6 x 5.5 but I can't help you with backspacing quesitons. I will be having them myself soon enough.
ok well that helps. thank you. whats the widest i can run on the rear with what backspacing? and what looks good on the front? i dont like wide tires on the front. i am going to run this tire http://www.nittotire.com/Tire/nt05 on the rear.
anyone??
![]() Join Date: Oct 2009
these might help get you in the ball park:
http://67-72chevytrucks.com/vboard/s...d.php?t=490367 http://67-72chevytrucks.com/vboard/s...d.php?t=513057 http://67-72chevytrucks.com/vboard/s...d.php?t=417647 |
Just saw this thread.... You can run a 8 to 8.5" wide up front, and a 10" in the rear. If you are thinking 18's, I would suggest an 18x8 and 18x10..... and for 20's, a 20x8.5 and 20x10.
That NT05 is a nice looking tire, and has good performance aspects. What I like, is it is available in a 315/35/20, which is also what I am running on the back of my 84 C10. Travis |
would you run those tires on the front? what else street performance tires should i look at? what size of tires up front?
also how wide could i run on the back? and i just like a narrower tire up front, i think it looks alot better in my opinion
#11 | |
I would run a 4.75" backspace on the rear. It is always good to measure to confirm, but that is backspace that works. You could squeeze the 315 in the rear.... it might rub a little but it can be done. As for the front, a 245 or 255 would be a good size to go with.
Take a look at the Nitto 420S as well. |
