Old 08-11-2012, 08:50 PM   #1
Black 'n' Blue
Black 'n' Blue's Avatar
Best lifting points for cab?
I am planning a 2 man lift with an engine hoist for my cab, and I was just wondering where the best place for the chains are without doing any damage.
-Justin.
The past cannot be edited, or erased. Only accepted.
Loud, proud and country by the grace of god!
Bradley Anderson 1997-2011
Black 'n' Blue is offline   Reply With Quote
Old 08-11-2012, 09:45 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Best lifting points for cab?
On mine I lifted the whole truck and unbolted and unhooked everything. Then set some 4x4 planks under the cab ratchet tied to the cieling of the garage andlowered the chassis and rolled it out
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 08-12-2012, 03:34 AM   #3
Prong
If you have the seat out of it and one door off, you can use the seat belt bolt holes. That's how I did mine when I was doing a frame-off resto.
Prong is offline   Reply With Quote
Old 08-12-2012, 09:34 AM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
instead of using chains a canvass tie down strap around the doors / roof works... i did mine with four guys and manual labor
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-12-2012, 11:36 AM   #5
willett
Another Day, Another Dollar
willett's Avatar
Ditto to the strap around the roof. It's advised that you remove the drip rails first though. I lifted my donor cab with pretty much everything in it with no problems
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 08-12-2012, 12:52 PM   #6
Kyeducator
On a regular cab I removed several by leaving on the doors and keeping them closed. I then used a 4x6 treated post from Lowes. On each end I drilled for eyelets to connect a chain so when it comes up the drip rail was not damaged. As it raises up against the door I added padding just to ensure the doors did not get damaged.
I also used a hoist that will spin so in case I need to turn the cab to load on a trailer.
Kyeducator is offline   Reply With Quote
Old 08-12-2012, 01:02 PM   #7
DBLSPRT68
DBLSPRT68's Avatar
I did this also. I used the seat belt holes in the back, and drilled two holes in the front (each side of the trans tunnel). I made an "X" with chain and used a cherry picker to lift the cab by myself. I also kept both doors on. You have to hook up to the chain about dash pad level, or it's going to flip over...... I found out the hard way, caught it before any damage.
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
