Finally starting the top refurbish...
So I finally figured it was nice enough out to take the top off and start the process of rehab on it...Just thought I would post a few pics...
Active Member
![]() Join Date: Mar 2005
Re: Finally starting the top refurbish...
Nice Truck!
Thanks Blownz!
Posted via Mobile Device |
Just a few updated photos of the process...
A little sanding and epoxy...and more sanding... |
Primered...and just a little more sanding...
2 coats of U-pol's Raptor Liner...
What epoxy did you use?
I used the Evercoat brand that is compatible with fiberglass/SMC.
I also sprayed the inside with appliance enamel Posted via Mobile Device |
Boosted Member
I'm really liking the idea of a spray on liner for coating the top....nice work. It looks great.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Post Whore
![]() Join Date: Feb 2000
Looks like you are doing a great job on it.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
![]() Join Date: Jul 2011
Looks great, nice work.
![]() Posted via Mobile Device
1969 C10 LWB GMC. 1970 K5 Blazer 1971 K10 Burb Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=529970 ![]() Shawn |
#13 |
Thanks fellas, I have to say that I was a little nervous at first. That spray liner kit was simple and user friendly.
#14 |
Boosted Member
Keep us in the loop on how it holds up (scratches, peeling, etc). I might go this way on one of my tops.
#15 |
needs more $$$
Looks great!!! What made you stay with white on the inside?
Also, did tops come white or black from the factory?
1970 2wd Blazer |
#16 |
I'm not sure if they were available in black and white, I left it white to help brighten it up inside. I'm tinting the windows before I put them back in as well.
I'm thinking about modifying a newer camper shell hatch to fit on he top...has anyone done this or seen it done? Any info? Posted via Mobile Device |
#17 |
You could get a top white or black. I have a black single wall and a white double wall.
