![]() Join Date: Sep 2011
Hood Hinge Replacement
My hood hinges are just plain wore out. Springs are weak, rivits are wallowed, etc. I have done some searches on this and saw that some of you were able to get new ones from GM dealers. Does anyone have part number or links to new hinges for sale?
'72 Custom K20 4wd LB |
The Older Generation
Re: Hood Hinge Replacement
See if this thread might help you out. http://67-72chevytrucks.com/vboard/s...d.php?t=525638 You might want to avoid the $600 ones though... ![]() If you buy used ones be sure and have the seller take the springs off and check them for loose pivot points. That is the only way you can tell if they are good or not. LockDoc
Thanks,
I might give these guys a try http://www.hoodhingerepair.com/index.html Posted via Mobile Device
