Old 08-12-2012, 07:28 PM   #1
Goinlow64
Rear mount Gas tank question...
I just finished mounting an LMC gas tank in my 64. However, I had a question on the vents on the tank. Besides the filler and sending unit, do I need to run any vents or returns? I would apprecaite any input or pics anyone can supply.
THanks!
Goinlow64 is offline   Reply With Quote
Old 08-12-2012, 09:18 PM   #2
LDO
LDO's Avatar
Re: Rear mount Gas tank question...
I'm thinking about the same tank, how low does it hang down? How was the install?
LDO is offline   Reply With Quote
Old 08-12-2012, 10:37 PM   #3
Rich 5150 69
Rich 5150 69's Avatar
If your not running a vented cap you`ll need to put a pigtail vent in the tank.. there are two trains of thought on a return line, stock mechanical pump you don`t need a return line,( although GM used a return lines on the `69 camaros with stock pumps ) electric pump you should run a return line, 3/8 or larger to the carb and 5/16 back to the tank and return needs to run almost to the bottom of the tank to eliminate vapors, this prevents the electric pump from deadheading the fuel pressure and creating excessive heat and causing the pump to shut down, (thermal overload protection ).
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 08-13-2012, 05:46 PM   #4
Goinlow64
Install wasn't too bad, but you sorta have to figure it out yourself. No instructtions, but could have been worse. The tank hangs about 9 inches below the bottom of the frame.
Old 08-13-2012, 05:49 PM   #5
Goinlow64
I am running a manual pump, so I won't need a return. However, what we are confussed about (and feeling stupid) is what lines hook to what ports on the tank. two of the ports we beleive are for returns/vents because they don't go down. However, the one nipple off the tank bends down a little, but it doesnt look like it goes all the way to the bottom. Sorry for the basic questions, I am just tryin to weed through this. THanks for the reply!
Old 08-13-2012, 07:15 PM   #6
LDO
LDO's Avatar
make sure you post some pictures (if it's not too much trouble). I need to decide on a tank soon...
Old 08-13-2012, 09:57 PM   #7
TR65
TR65's Avatar
My tank came with a vent fitting on the top of the tank. It also came with a check valve so that gas won't run out of the vent in case you put the shiny side down.
Here is a pic. I picked up the screen filter at Advance. I mounted it up between the inner fender and the bed side.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
