08-12-2012, 08:09 PM | #1 |
vortec cam options..
ok i am pulling the ole 350 out of a 98 chevy 3/4 ton...now my question is the vortecs are roller cams right can i go back with a hydraluic tappet cam...and be ok or are there specific reasons that i have to use a roller cam back in it
08-12-2012, 10:18 PM | #2 |
Registered Truck Offender
Re: vortec cam options..
Heads do not care which cam and valve train you use. You can use hydraulic / solid / flat tappet or roller. Just don't go over .45 lift without modifying the heads for it.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
08-12-2012, 11:44 PM | #3 |
Not worried about the heads....I know the vortecs have a roller block...can I use a Flatt tappet can in place of it
Posted via Mobile Device |
08-12-2012, 11:49 PM | #4 |
60-66 Nut
I see absolutely no reason to go backwards to a flat tappet cam. Why risk the flat tappet going flat with today's oils, and ruining the entire engine? For what you will spend on a good flat tappet cam and lifters, you can pretty much pay for an upgraded factory style roller cam. You only have to replace the cam, The roller lifters can be reused, as long as they are in good useable condition.
I would go with this cam. It is affordable, and is a good street performance cam. This is what GM puts in the HT383 and the Ram Jet 350 crate engines. When used in the Ram Jet 350, 1.6 rockers are used. http://www.summitracing.com/parts/NAL-14097395/
08-13-2012, 12:34 AM | #5 | |
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
08-13-2012, 10:14 AM | #6 |
mini truck racer
I agree stay hydraulic roller . 4th gen F-body (or any LT series) LT-1 cam is also a good choice for factory parts . You'll have to check the specs , but i think 94' and/or 96' Z-28 had a similar cam to the specs Captain fab gave you .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
08-13-2012, 02:54 PM | #7 |
You can go either way but you can do so much more with a roller cam. Plus your block is all set up for it. People with non roller blocks spend big bucks to retrofit a roller cam into them. Flat cams have come under a lot of criticism due to the new oils not having zinc, quality control , and last but not least the cheap foreign lifters. Like someone said buying cheap can get expensive. I try not to buy foreign crap that could affect my American engine. A poor fitting Taiwan fender will not hurt much else. A lifter or cam gone bad can hurt a lot of surrounding parts.
