truck shuts off at red lights
I am new to this but lets try it. I have a 69 stepside that shuts off at the red lights but starts right back up. I have to rev it up or hold the gas pedal down and brake at the same time.
I have the gas tank mounted in the rear with a sumitt fuel pump and a 350sbc with a 650cfm edelbrock. anyone have this problem or can help thanks alot |
It'll Buff Out!
![]() Join Date: Apr 2007
Re: truck shuts off at red lights
do you know what your rpm's are at when idling? do you have air? if so is it only happening when its running? fuel filter good?
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
1. If using an HEI distributor set up, check wiring from distributor, often I see that these are wired incorrectly or not using the proper guage of wire causing resistance issues that can cause stall.
2. Type of Carb? Eldelbrock floats can stick causing idle issues under load. Clean with a good quality carb cleaner spray to start but will probably need a carb rebuild. 3. Fuel boil, does it stall only after being warmed up on a hotter day? Try a spacer between carb and mainfold, cheap and easy fix and slightly increases performance anyway if not the main issue.
TallBoy |
thanks for all the info going to look into all the ideas. Its a new carb but will check it out.
Make sure its not lean on the idle curcit while your looking at, a lean setting can cause it to just up and die like that.
Posted via Mobile Device |
