Old 08-13-2012, 02:06 AM   #1
MikeS.
MikeS.'s Avatar
Rhino lining
Has anyone Rhino-lined the inside(cab) of their truck?
I'm thinkig of doing this as protection for the metal and wood on my Burb. I'd top the front with a rubber mat like the original.
I did have the new gas tank done.
Thanks,
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 08-13-2012, 03:20 AM   #2
BigDan3131
BigDan3131's Avatar
Re: Rhino lining
I have shot many trucks and cars inside the vehicle with Rhino and it just depends on which gun they are using is how much volume it can put down. If its the new style I put down five coats on the floor and three on the sides. If its the old style low pressure system it goes on very heavy. Its either Rhino or rubberized paintable undercoating from Evercoat, either works well. You just have to mark all the holes you do not want filled when getting the Rhino otherwise your re-tapping threads or drilling out the holes.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-13-2012, 07:17 AM   #3
spacedebris
Re: Rhino lining
I've been considering that as well. However, I'm still torn between Rhino or Lizard Skin. Although, I am leaning toward Lizard Skin.
Rhino has the toughness. Once its on, its on. However, besides getting in and out of the cab, it really doesnt take much of a beating.
On the other hand, with my Cummins and its turbos as well as the exhaust just inches under my firewall/floor, the insulating properties of the Lizard Skin is very appealing. Lizzard skin also has the added benefit of acoustic deadening. I would guess that Rhino will also have an affect on sound but I dont know how much.
I also understand that both are paintable.
An added benefit to either is that they both claim to be environmentally friendly. Maybe someone who has used both will have some more info for us.
However cost is another thing. From what I can tell, the Rhino is at least 50% cheaper (when using both lizard skin formulas)
spacedebris is offline   Reply With Quote
Old 08-13-2012, 09:40 AM   #4
mike14_07
mike14_07's Avatar
Re: Rhino lining
i have thought about this as well. my biggest concern is getting it in the debris drains in the rockers, cab corners, etc....
mike14_07 is offline   Reply With Quote
Old 08-13-2012, 11:58 PM   #5
piratexpress1369a
piratexpress1369a's Avatar
Re: Rhino lining
por-15 but it is pricey
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 08-14-2012, 12:19 AM   #6
jocko
jocko's Avatar
Re: Rhino lining
between rhino and lizard, i'd go lizard skin - there are 2 types of lizard that can be put down together, one for heat and one for sound. (they may offer a of combo type now, not sure).
every rhino lining spray i've ever seen leaves a VERY thick coat and that seems like it would cause some issues inside a cab.
For me - painting with POR 15 has always, always turned into a giant mess. But then again, that's just me, might have something to do with my painting prowess, or lack thereof.
Old 08-14-2012, 12:27 AM   #7
kenmel
kenmel's Avatar
Re: Rhino lining
You might try out Raptor Liner. I have used it on 2-3 vehicles and it has always held up great even on a Jeep TJ rockcrawler. You can get a whole kit off of ebay including the guns to shoot it for around a 125. More than enough to do 4-5 coats on the underside of the fenderwells, inside of the cab and the interior bedsides and pretty easy to do.
kenmel is offline   Reply With Quote
Old 08-14-2012, 02:49 AM   #8
BigDan3131
BigDan3131's Avatar
Re: Rhino lining
Jocko, that's the old style system. If a company springs for the Graco machine it comes out like a Line X coating.
Old 08-14-2012, 11:57 AM   #9
FetchMeAPepsi
FetchMeAPepsi's Avatar
Re: Rhino lining
I thought about doing this on an old mud truck, but that was stuff that you rolled on instead of sprayed. I thought it was all rolled on
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline   Reply With Quote
Old 08-14-2012, 12:17 PM   #10
MikeS.
MikeS.'s Avatar
Re: Rhino lining
My buddy owns a Rhino shop. It's where I'm working on my truck with his help. He'll Rhino it for cheap.
So I guess I should ask, any reason NOT to Rhino it?
Past Master
Old 08-14-2012, 12:20 PM   #11
FetchMeAPepsi
Re: Rhino lining
scratchy floors?
I guess it *could* seal in some problems but you can get that with paint too so really nothing other than the feel should be different.
Step by steps:
Old 08-14-2012, 04:41 PM   #12
spacedebris
Re: Rhino lining
About the only reason not to rhino, at least as far as I can tell, is that once its on, its on. If for any reason you need to do any kind of repair/change, it would be a ***** to get it off.
Other than that, I dont think there would be any drawbacks. Especially since you said you would cover it with a rubber mat.
Old 08-14-2012, 04:58 PM   #13
ChuckW
ChuckW's Avatar
Re: Rhino lining
I've got Dupli-color Bed Armor in mine. Seems to hold up pretty well... They're probably all about the same though.... Good Luck!
ChuckW is offline   Reply With Quote
Old 08-14-2012, 09:10 PM   #14
jocko
jocko's Avatar
Re: Rhino lining
THANKS Big Dan, I didn't know that. Guess I got my '01 chevy sprayed too soon! (i.e. in 2001). Thanks again!
Old 08-15-2012, 05:06 AM   #15
amccomb
Re: Rhino lining
Whatever you do don't rhino line over any wood surface it traps the moiture in the boards and rots them!! The guy who I bought my truck from did this and ruined the wood bed. The inside of my cab was also rhino lined and it works great and has held up to abuse well.
amccomb is offline   Reply With Quote
Old 08-15-2012, 11:09 AM   #16
MikeS.
MikeS.'s Avatar
Re: Rhino lining
Thanks for the info about the wood I would've had it rhino lined too.
Past Master
Old 08-15-2012, 11:48 AM   #17
kenmel
kenmel's Avatar
Re: Rhino lining
you could just line the tops and sides of the boards and you should not have any moisture problems
Old 08-15-2012, 11:21 PM   #18
badriand
badriand's Avatar
Re: Rhino lining
Haven't done the inside roof but my inside doors are bedliner and all around door framing.
badriand is offline   Reply With Quote
Old 08-16-2012, 02:27 AM   #19
BigDan3131
BigDan3131's Avatar
Re: Rhino lining
One other thing about rhino is you can just leave it glossy if you prefer. Texture doesn't have to be done. I don't texture the underside of the bed or wheel wells as it makes cleaning with a hose much easier. I will have pictures up in about a month or so because I'm rhinoing about 85% of my new project truck.
Old 08-16-2012, 07:30 PM   #20
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Rhino lining
I did and love it. Check it out in my build thread.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 08-17-2012, 03:01 AM   #21
MikeS.
MikeS.'s Avatar
Re: Rhino lining
61 fl apache, I like what you did with that truck. The Herculiner looks good in there.
Past Master
