08-13-2012, 03:12 AM | #1 |
75 chevy with a 700r4 trans
Hi, i'm new in here, i have read some of the articles in here... i have a 75 chevy c-10 scottsdale longbed, y have changed the tranny 350 for a 700r4, i dont know if it was a good idea or a bad idea, it has a rochester quadrajet carburator and it has the universal tv cable, it has been calibrated from the person that rebuild the transmission... my question is, that if i need something like an adaptor for the carburator ir of its going to work fine how it is... i want to post some pictures from the carb on my truck and a picture for my dad's truck, he has a 93 chevy silverado tbi carb... will apreciate any help... thanks...
08-13-2012, 09:02 AM | #2 |
Robert Olson Transport
Re: 75 chevy with a 700r4 trans
cant help[ you with your question about the trans but welcome.. if you go to advancd reply there is a manage attachment button that will allow you to post pics
08-13-2012, 11:59 AM | #3 |
BAD BOW-Silverado XST
Welcome to the site.
First, does the end have an adjustable little set screw? The 350TH and 7004 transmission connect the same way. If so, you can use part #42 from this page: http://www.transmissioncenter.org/70...ometer%20Parts Information to know about a 700R4. http://www.transmissioncenter.net/700r4.htm Almost everything you need to know about swapping a 350th with a 700R4: http://transmissioncenter.net/700R4_Swap_Info.htm Parts for a 700R4 conversion: http://www.transmissioncenter.org/700r4_Parts_List.htm The calibration he talked about was the TV cable setting for his carb and bracket. You need to make adjustments for your set up. Set the cable by this method: http://www.73-87.com/7387garage/drivetrain/tvcable.htm |
08-13-2012, 03:50 PM | #4 |
Couple of things to look for:
IRC in 93 GM switched from 700R4 to 4L60E - if transmission has a round harness plug on a passenger-side of the transmission - it is a 4L60E which requires TCM or PCM to operate and you are out of luck for a simple swap. If it is older 700R4 with 4 wire plug on a driver side of the case make sure that it has been built with upgraded parts (4L65E) to handle its duties. You'll pickup about 2 to 4 MPG depending how you drive on a highway. The lockup torque converter will require some wiring. The BTO overdrive sells correct TV cable bracket and TV cables. In fact correct TV cable adjustment is paramount to 700R4 longevity - you have been warned!! //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
08-13-2012, 05:27 PM | #5 |
1965 Chevy C10, 2005 4.8L/4l60
bowtie overdrives has your bracket and can explain how to ensure it is set up properly.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-13-2012, 05:56 PM | #6 |
If the 1975 has its original carb then you'll be fine. After 1973 GM switch all the Q-jets to the same throttle arm on the carb as the later cars used which is the same as those equiped with a 700R4. I have a 1974 with a 700R4 in it and there is no reason to change over to any of the aftermarket kits that "fix" the geometry. On earlier carbs, then yes but a factory carb built after 1973....nope.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
