Heater core install
Is there any particular reason why it would NOT be a good idea to install the core upside down in the housing so as not to have to criss criss the hoses? Another words, why can't the bottom hose go to the water pump and the top hose go to the intake manifold as long as you flip the core?
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431 Member of the 1-Ton Club! http://www.eastcoastcarandtruck.org |
Re: Heater core install
In my case, the hoses were different sizes.
In my opinion, it works best to have the seat out so you have room to flop your body around while standing on your head. -ashx2 |
Yes, mine as well but as long as I use thw correct size hose on the correct side of the core and that hose goes to where it's supposed to does it matter if the core is installed upside down is the real question.
My understanding is it prevents forming an air pocket inside the core.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
I am a Referee of life.
I did and it seems to work fine.I like the cleaner look of it this way.I live in a fairly mild climate tho.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: Feb 2010
Yes from what I can understand, the core is setup to feed from the bottom, and exit from the top.. this keeps more water in the core for a better heat exchange (warmer air in the heater). You may or may not even notice the difference if your coolant system is full.
Try it out and see how you like it. Shawn |
