Old 08-13-2012, 11:06 AM   #1
MaydayNeal
Who's bagged their AD stock frame??
I see plenty of S10 swaps bagged, but just wondering about a stock frame option. It should be ok right??.....my initial plans is to go with a M2 IFS and a triangulated 4link out back. I've done a few searches out there without much luck.....so just looking for any examples out there.
Thanks!!
Neal
MaydayNeal is offline   Reply With Quote
Old 08-13-2012, 08:49 PM   #2
parkwood
parkwood's Avatar
Re: Who's bagged their AD stock frame??
Thanks!!
Neal
might be what you're looking for, some before and after shots.
parkwood is offline   Reply With Quote
Old 08-13-2012, 09:41 PM   #3
Daze57
Daze57's Avatar
nice work !
Daze57 is offline   Reply With Quote
Old 08-14-2012, 12:46 AM   #4
parkwood
parkwood's Avatar
Originally Posted by Daze57 View Post
nice work !
thank you.
Old 08-14-2012, 08:24 AM   #5
98layinframe
98layinframe's Avatar
Thats a nice looking suspension setup! Couple questions though.. what height tire are you running and will the bag setup lay the running boards on the ground? If not how far off the ground does the body sit with no notch? Im also still debating on if I should run the stock frame or s10 frame myself..
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 08-14-2012, 09:39 AM   #6
Gabbyp
Parkwood,
Who is the manufacturer of your rear suspension set up. Installation looks good.
Gabbyp is offline   Reply With Quote
Old 08-14-2012, 10:28 AM   #7
parkwood
parkwood's Avatar
Originally Posted by Gabbyp View Post
Parkwood,
TCI is who i use.. glad you liked it..
Old 08-14-2012, 10:27 AM   #8
parkwood
parkwood's Avatar
the tires are 15's 215's in front and 235's in the rear. and as you can see it does not lay the boards on the ground, maybe in high grass it would look that way.. i did not want to set it up so it hit the ground just in case something went wrong while driving at 70 mph. wouldn't be good to hit the ground going that fast.. i think it still looks good even though it's not sitting on the ground...
Old 08-14-2012, 10:06 AM   #9
zenchal26
zenchal26's Avatar
not positive but the frame is not notched over rear axle so I dont think it will get to the rockers.
zenchal26 is offline   Reply With Quote
Old 08-14-2012, 10:30 AM   #10
parkwood
parkwood's Avatar
if you want to call it notched, the frame is notched about an inch just to get the bump stop up a little so the center of the rear end just missed the floor..
Old 08-14-2012, 10:30 AM   #11
MaydayNeal
Hey Parkwood....
Thanks and very nice work. This is exactly what I had visioned, right down to not notching the frame. I'm not looking to drop into the weeds....but do want the option of a lower stance when I want......so I too am interested in seeing just how low this setup looks and if this was your design or a kit from a manufacture??
Thanks again!
Neal
Old 08-14-2012, 10:33 AM   #12
parkwood
parkwood's Avatar
Hey Parkwood....
Thanks again!
Neal
sorry i can't take credit for the design, everything on the frame came from TCI here in calif.
Old 08-14-2012, 10:55 AM   #13
98layinframe
Thats a beautiful burban parkwood!
Guess one last question.. whats the front track width of the mustang II setup? Then whats the wheel specs.. backspacing and width. Thanks
Old 08-14-2012, 12:02 PM   #14
parkwood
parkwood's Avatar
I don't know what the track width is for the Mll front end but i'm sure it's narrower than the stock set up by about 2".. the front rims fit nice without any rubbing anywhere and they are 15x7 with 3 1/2" bs.. the rears are 15x8 with 4" bs..
And so you know this suburban is not mine i built it for some friends in So. Calif. But glad you liked it..
