Old 08-13-2012, 11:27 AM   #1
yalpngulp
front spring cutting question
I have 2 1/2 drop spindles and I just bought some Belltech 2" lowering springs, but I would like another 1-1.5 inches lower. Does anyone recommend cutting the brand new springs or is there another way to achieve it?
yalpngulp is offline   Reply With Quote
Old 08-13-2012, 11:35 AM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: front spring cutting question
I would check and make sure that the springs are seated and settled properly. I've had issues in the past where the spring didn't sit in the lower or lower cup properly. If it looks okay, I've cut new springs before. It hurts a little cutting into a new part, but you gotta do what you gotta do. Good luck... jc
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 08-13-2012, 11:42 AM   #3
yalpngulp
will cutting them affect the ride comfort?
Old 08-13-2012, 03:15 PM   #4
66clow
66clow's Avatar
More spring more comfort, cutting them will give you a stiffer ride the more you cut. You may want to put it all together ride it and then decide. Once you cut there is no turning back.
66clow is offline   Reply With Quote
Old 08-13-2012, 04:14 PM   #5
forestb
forestb's Avatar
Have you tried them on yet. Sometimes it takes a while for them to settle. You wouldn't want to cut them to find out later that it is two low when they settle. 6" is vary low watch out for speed bumps and make sure your front wheels will fit.
forestb is offline   Reply With Quote
Old 08-13-2012, 04:20 PM   #6
yalpngulp
they are on in the picture. it sat nice with 15" wheels, but with the 20's, i would like to get a bit lower
Old 08-13-2012, 05:38 PM   #7
Turkey
Turkey's Avatar
cut it
Turkey is offline   Reply With Quote
Old 08-13-2012, 09:03 PM   #8
SoNorth
Cut your stock springs down if you don't want to cut your new drop springs.
SoNorth is offline   Reply With Quote
Old 08-13-2012, 10:25 PM   #9
YBNORML
YBNORML's Avatar
I cut the the drop springs on my blazer, I am running 2-1/2" drop spindles with 2" drop springs and I cut off one coil. I am happy with the ride.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 08-14-2012, 02:54 AM   #10
BigDan3131
BigDan3131's Avatar
Is the motor in it? If its not you better wait until it is. When I cut my springs I cut one loop from each end rather than both from one end, but that was on my ElCo. I haven't pulled apart my front end yet to find out.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-14-2012, 09:13 AM   #11
yalpngulp
yes the motor is in. I think i'll take the advice and drive it for a week and then decide whether to cut a loop out of them like YBNORML said.
Old 08-14-2012, 09:21 AM   #12
glos55
glos55's Avatar
Smart choice...mine settled after driving for awhile
glos55 is offline   Reply With Quote
Old 08-14-2012, 11:08 AM   #13
cori 64
cori 64's Avatar
cut them!!
cori 64 is offline   Reply With Quote
Old 08-14-2012, 12:28 PM   #14
brokenspoke
brokenspoke's Avatar
I would cut 1/2 loop at a time
brokenspoke is offline   Reply With Quote
Old 08-15-2012, 04:23 PM   #15
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: front spring cutting question
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 08-15-2012, 04:29 PM   #16
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
As mentioned, drive it for a couple weeks, see if it settles any, as they usually do just a bit. Then cut if it still isn't low enough. The spring rate will increase resulting in a stiffer ride, but sometimes a higher spring rate is desirable on a lowered vehicle since you are working with less travel after all.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
