Old 08-13-2012, 12:41 PM   #1
74 stepside
74 stepside's Avatar
350 vs 700r4 length
I tried the search before I asked, but couldnt find an answer. My 74 shortbed originally came with a 350/350 combo. They are both long gone now. I have a 400 to install but now might be trading it for a 700r4. Im guessing my 350 had a 9" tail shaft but not sure. Am I going to need to lengthen or shorten my drive shaft?? Is the column shift brackets going to adapt or do I need them from an 80s truck?? Thanks for any info, Matt.
74 stepside is offline   Reply With Quote
Old 08-13-2012, 12:46 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: 350 vs 700r4 length
my 73 C10 came with a th350, I swapped a 700 in, the drivesahft did not need to be shortened at all.
Can't help on the linkige part, I am running a floor shifter.
bigblock73 is offline   Reply With Quote
Old 08-13-2012, 12:53 PM   #3
rs72z
rs72z's Avatar
Drive shaft and the linkage will both work.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 08-13-2012, 01:45 PM   #4
Rich84
Rich84's Avatar
You do have to move the cross member..
Rich84 is offline   Reply With Quote
Old 08-13-2012, 05:27 PM   #5
74 stepside
Well if my stock driveshaft will work that will save me some coin. Thanks for the info.
Old 08-13-2012, 06:17 PM   #6
Jonboy
Slots go on anything!
My '74 had the long tailshaft, and the 700R4 went right in. I did have to move the crossmember, like Rich mentioned. Not an issue at all. Driveshaft and linkage works like a charm.
1974 Jimmy- 5.3/4L80e/NP241
Old 08-13-2012, 06:31 PM   #7
406 Q-ship
406 Q-ship's Avatar
If your truck had a long shaft TH350 then you don't need to do anything, the driveshaft slip right in. How do I know, my 1974 was an original TH350 (they originally came with long shafts) and I put in a 700R4 and used the original drivesaft.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 08-13-2012, 07:12 PM   #8
74 stepside
I dont remember if my 350 was a long tail or not. Does one of you have a measurement of the driveshaft?
Old 08-13-2012, 08:50 PM   #9
clinebarger
A "short tail" TH350's extention housing is roughly 6" long.
A "long tail" TH350's extention housing is roughly 9" long.
clinebarger is offline   Reply With Quote
Old 08-14-2012, 12:45 AM   #10
74 stepside
As I stated above I dont have the trans anymore so I cant measure it. Thats why I asked the length of driveshaft.
Old 08-14-2012, 01:57 AM   #11
beamn7
Linkage should work just fine. Just need to change the indicator in the dash. Easy swap.
beamn7 is offline   Reply With Quote
Old 08-14-2012, 07:47 AM   #12
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Transmission mounting and housing sizes.
http://www.tciauto.com/tc/trans-dim
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 08-14-2012, 01:38 PM   #13
406 Q-ship
406 Q-ship's Avatar
If you can wait a bit I can slide under my truck and measure the driveshaft on my truck.
Old 08-14-2012, 01:59 PM   #14
74 stepside
Cool link, thanks.
Old 08-14-2012, 02:00 PM   #15
74 stepside
That would be cool, thanks.
Old 08-14-2012, 02:02 PM   #16
74 stepside
Do you know where I can get the new indicator besides a wrecking yard?
Old 08-14-2012, 02:21 PM   #17
INSIDIOUS '86
INSIDIOUS '86's Avatar
Neighbors truck?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 08-14-2012, 03:10 PM   #18
beamn7
Originally Posted by INSIDIOUS '86 View Post
Neighbors truck?
If that option doesn't pan out, LMC truck (cheapest) has them along with a few others.
On Ebay:
http://www.ebay.com/itm/GMC-C-K-R-V-...item53ec2202a7
Classic Industries:
http://www.classicindustries.com/truck/parts/17140.html
LMC:
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=136
(It says it is for later models than yours but that is only due to the availability of the 700, it will mount just fine with no mods)
Or, Yes, Junkyard but if you are like me, you most likely will leave the junkyard with it and a host of other parts you found and an empty wallet....
Old 08-14-2012, 04:14 PM   #19
rcsweet21
i dropped a built 1966 327 ci engine with a 1997 4l60e in a 1986 c-10 that had a 305 ci and a th350 and all I had to do was move the cross member and the shifter worked fine also
rcsweet21 is offline   Reply With Quote
Old 08-14-2012, 04:16 PM   #20
gchemist
gchemist's Avatar
Oh yea, rookies!!
http://transmissioncenter.net/700R4_Swap_Info.htm
