Hot Damn - Here I Am!!
WTB - Factory Cruise system for '71
I know that this is a long shot but I gotta try.
![]() Would a cruise control for a 71-72 Chevy car be the same such as out of a Chevelle, Monte Carlo or Impala? Robert
My vehicles: '90 Silverado Sport '71 Chevelle SS Convertible '70 C-10 - My Grandfather bought it new - original un-restored |
SWB 4x4 Collector
![]() Join Date: Jun 2001
If you scroll down... here in the parts section. There should be a Restored set for a '67 ... it looks just like the setup in my 71' and is correct according to LMC.
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#3 | |
Robert
Good luck on the search, this is 72 I believe I have a set up but my switch has the word cruise master across the bottom and a button in the center.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
My cruise button.. correct for 70-72. It came off a 72.
![]() Join Date: Dec 1999
Rod
The CRUISE MASTER button that you have in your hand was a 72 only item. 71 and earlier had the button in the turn signal switch. The reason I heard for the change had to do with warranty work. The factory installed (71 and earlier) had problems so they went to a dealer installed (72 only) to get around having to keep fixing them. My .02
72 Shortbed fleetside 402 BB, AC, Posi 72 Super Cheyenne Longbed 350 49,000 original miles and My dad ordered it new 66 Chevy Caprice 2 dr 74 Honda CB750 New Palestine, IN |
Robert
I have an extra turn signal arm with the cruise button you can have for $15 plus shipping. It is chrome and the button and plastic on the end are black. I don't know if it is correct of not. I can post a pic of it if someone would be able to tell. Mark
If it's off a tilt column you can consider it sold. I sent you a PM Mark.
Robert
#9 | |
I wonder if it could be changed over to the button on the turn signal stalk? Would you be interested in selling or trading your cruise system? Robert
If that cruise lever is for 67-70 I'll take it regardless if its not for a tilt. Rod
Then there is this type cruise master button... maybe 72 also.. dont know but my parts book lists the earlier one of mine I posted as correct for 70-72.
This would work also though.
These kind would work also.. I must have ten of this type laying around.
