08-13-2012, 05:01 PM | #1 |
High hump versus low hump comparison
Low and high hump next to each other for comparison.
08-13-2012, 09:09 PM | #2 |
Re: High hump versus low hump comparison
Thanks for the picture comparison, always wanted a side by side on this.
That's a heck of a coffee stain on the low hump! |
08-13-2012, 11:17 PM | #3 |
But Found Her 25yrs Later!
Is there also a bolt-in low-hump?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
08-13-2012, 11:20 PM | #4 |
10-06-2013, 06:07 PM | #5 |
By looking at the pictures, I'm guessing the low hump floor mat won't work with the bolt-in low hump tunnel.
10-07-2013, 02:08 AM | #6 |
Senior Enthusiast
I've read long ago the low hump mat will fit either low hump floor. Bolt in or part of the floor the shape ends up the same. From what I've seen all high humps are bolt in. The low humps are a mix. I do know from experience (the hard way) the low hump mat is about 5-6" too narrow to cover a high hump floor.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
10-07-2013, 09:58 AM | #7 |
My low hump is bolted in and my mat fits fine.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
10-07-2015, 04:30 PM | #8 |
I'm switching to a th350,
Are the bolt in low humps the same size floor wise as the high hump? What I mean, Can I remove my high hump and the low hump will fit right in and bolt to the same holes?
10-07-2015, 05:57 PM | #9 | |
1961 crewcab
in the picture of yours that piece has been cut up. and in post # 4 you can see the 2 different firewall pieces that should be welded in and that the low, or high hump bolts to.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
