Old 08-13-2012, 05:37 PM   #1
fostrem
Blown Head gasket or intake manifold?
First off my truck is a 76 k10 with a 350sbc in it. The reason I got to the conclusion that it was a head gasket was that it was smoking a ton. It would billow out the exhaust and the once the truck heated up, some smoke would come out of the left side of the engine. The truck barely runs as is. It can barely idle and eventually dies if i don't mess with the throttle even though the idle is set high. I set the initial timing to about 10 degrees but haven't been able to set total because the thing won't run long enough. I think its the head gasket. I checked the coolant over flow tank which was bone dry and when i drained the coolant, it still had a nice green look to it, not milky and no traces of oil. I then checked my oil which had a tinge of gas smell. Before I rip the heads off, do you think it is the head gaskets? intake manifold gasket? The only thing that worries me is the amount of smoke. The smoke is white ish and is not steam it smells like burning gas/oil.
Thanks in advance
fostrem is offline   Reply With Quote
Old 08-13-2012, 06:16 PM   #2
fostrem
Re: Blown Head gasket or intake manifold?
I just ripped the valve covers off and they are completely clean, normal build up but no milky/lotion sludge that would be signs of coolant oil mixing.
Old 08-13-2012, 06:21 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
if the oil is full of gas id be looking at the fuel pump
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-13-2012, 06:31 PM   #4
fostrem
would that explain all the smoke though? especially the smoke coming out of the passengers side of the engine?
Old 08-13-2012, 06:50 PM   #5
rwhit57
rwhit57's Avatar
The fuel pump leaking gas into the crank could do this, it thins the oil so much it blows by everything. Certainly an inexpensive place to start.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 08-13-2012, 07:18 PM   #6
fostrem
ok i will replace the fuel pump in a few hours. is there an easy way to tell if my intake manifold gasket is blown?
Old 08-13-2012, 08:47 PM   #7
rwhit57
rwhit57's Avatar
Be sure and change the oil and filter. An intake gasket will suck air or leak oil. One step at a time. Change the pump, oil and filter, might solve it.
Old 08-13-2012, 09:03 PM   #8
Corts60
Just here to tinker
Corts60's Avatar
The first thing you need to be doing is a compression check. Don't tear into it without knowing the condition of the cylinders/combustion chambers/valves. Then you'll know what to look for. If your trying to do it cheap, you may have to only pull one head if there is a bad head gasket.
Old 08-14-2012, 07:14 AM   #9
xrcr
are any of your plugs wet?
xrcr is offline   Reply With Quote
Old 08-14-2012, 03:33 PM   #10
fostrem
no none of the plugs are wet
Old 08-14-2012, 07:27 PM   #11
fostrem
ok so heres the update. I changed the fuel pump, oil, oil filter and fuel lines because they were cracked. right when i started it up it smoked like usual then it seemed to blow it off and the smoke was gone! no more smoke coming from the tail pipes and the engine sounds pretty good. needs some timing adjustment but thats easy enough. the only problem i have now is a good amount of smoke coming from the passenger side of the engine. i attached the picture of where the smoke was coming from. seemed to be from my exhaust. need new gasket? thanks for all the help so far
Old 08-15-2012, 01:42 AM   #12
rwhit57
rwhit57's Avatar
Looks to me like the valve cover gasket leaking onto the exhaust manifold.
Old 08-15-2012, 06:20 PM   #13
fostrem
ok now i am getting quite a bit of smoke out of the exhaust but only when accelerating. it is not water vapor but lingering smoke, kind of smells like burning oil. and also upon immediate start up, the oil pressure jumps to about 45 to 50 lbs. could these be symptoms of valve seals?
Old 08-15-2012, 07:41 PM   #14
rwhit57
rwhit57's Avatar
Usually smoke on start up is the valve guides, and really not a big issue.What kind of oil did you put in? My first thought is it will probably straighten up and be ok, I would just drive it easy for a days and not be pushing it. I would have put some 10-40w or some straight 30w, oil in it.That oil press sounds fine. That gas in there probably knocked all kinds of stuff loose, I think I would run it a couple of hundred miles and change the oil again.
Old 08-16-2012, 10:09 AM   #15
fostrem
Should I be worried about the smoking out the exhaust while driving?
Old 08-16-2012, 10:22 AM   #16
fostrem
Should I be worried about the smoke out the exhaust while driving it?
Old 08-16-2012, 11:46 AM   #17
rwhit57
rwhit57's Avatar
Well if it doesn't slow down or quit yes. You also might try an oil additive, maybe some of the guys could suggest something. Maybe Restore, or that stuff Sea foam. That gas in the oil could have caused permanent damage, but if it's not knocking or rattling it's worth a shot to try to work it out. A little thicker oil an additive or two and drive it easy and see what happens.
Old 08-16-2012, 08:16 PM   #18
fostrem
well after a compression test, the passengers side cylinders all read 147-150. the drivers side how ever, cylinders 1 and 3 have no compression and 5 and 7 have very low (around 60). Is this the head gasket?
Old 08-17-2012, 03:12 AM   #19
rwhit57
rwhit57's Avatar
Well that sucks. It could be a head gasket since it's isolated to one side. Sounds like it's time to tear into that side and start inspecting things. Did it run ok before?
Old 08-17-2012, 04:40 AM   #20
fostrem
it hasn't run well for a few months, ever since i had some valve work done. I'm thinking there could be bent valves on cyl1 and 3. I'm tearing that side down tomorrow ill let y'all know what the problem is
Old 08-17-2012, 03:48 PM   #21
McMurray76
I think I'd be talking to the guy that did the valve work.
McMurray76 is offline   Reply With Quote
Old 08-17-2012, 04:17 PM   #22
fostrem
i would love to but the guy quit the shop and the jacka** of an owner wants to charge me more
Old 08-17-2012, 06:15 PM   #23
rwhit57
rwhit57's Avatar
[QUOTE=fostrem;5543283]it hasn't run well for a few months, ever since i had some valve work done. /QUOTE]
This is where we should have started out.
Old 08-17-2012, 08:49 PM   #24
88Jimmy4x4
88Jimmy4x4's Avatar
sounds just like my 76, mine was a cracked head
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 08-18-2012, 10:56 PM   #25
Dead Parrot
Before pulling the head, try backing off the rocker arm nuts about a half turn or so. If the mechanic over tightened them, it could cause the low compression.
Dead Parrot is offline   Reply With Quote
