08-13-2012, 06:30 PM | #1 |
Radiator Saddles
I recently replace the radiator in my '85 GMC 3500. I installed a new aluminum 4 core radiator from Champion that was supposed to be a direct replacement. The radiator is just a bit shorter that the stock one (about an inch) letting it sit loose when the top cover is installed. I took up the extra space with some rags so the new radiator can't move around. Does anyone know where I can buy some rubber saddles that are taller than stock? Champion didn't have any or any solutions to the problem.
08-14-2012, 07:54 AM | #2 |
BAD BOW-Silverado XST
Re: Radiator Saddles
Did you install a BB radiator bolt down bracket? SB used two seperate brackets. A BB bracket is a single large bracket. I think LMC still has them for $20. You can also buy the rubber upper and lower bushing from them too.
08-14-2012, 09:07 AM | #3 |
Robert Olson Transport
i had a similar situation and i wound up using some hold downs from a newer generation truck its been a while i forget what year but it was a chevy product
08-14-2012, 09:11 AM | #4 |
08-14-2012, 09:18 AM | #5 |
78K & 79C Jimmys
Ive added a small bit of rubber hose to wedge things before
take a 5/8ths hose as long as the saddle and wedge it in or cut a piece .5 inch out of the length
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
