Old 08-13-2012, 08:43 PM   #1
slugish
Slugish
Plug wire routing /pics please
Whats some good ways to route plug wires without spending a fortune on those fancy gizmos that attach to your valve covers & you thread your wires thru. They look great & neat but Idont want to spend 75.00-80.00 on something like that. Also should Ikeep my wires up off the valve covers .
Ideas & pics would be great .
slugish is offline   Reply With Quote
Old 08-13-2012, 09:09 PM   #2
BIGTEN
BIGTEN's Avatar
Re: Plug wire routing /pics please
You could use zip ties.
BIGTEN is offline   Reply With Quote
Old 08-13-2012, 09:18 PM   #3
mongoose
mongoose's Avatar
lol yeah i've always used zip-ties..
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 08-13-2012, 10:43 PM   #4
Billy81
Billy81's Avatar
I have used zip-ties just like that i think i found out about that trick in an old hot rod magazine.
Billy81 is offline   Reply With Quote
Old 08-14-2012, 09:50 AM   #5
exfordman
zip ties can actually make a good look, i saw it on spike tv's trucks once, just use a big one around all 4/3/2 (however many you have at the same spot) and then use a small one to go inbetween each wire, i did it with my old cavalier and it looked pretty good actually, ill come up with pics sometime soon
exfordman is offline   Reply With Quote
Old 08-14-2012, 09:51 AM   #6
exfordman
darn mongoose beat me too it, nevermind
Old 08-14-2012, 12:33 PM   #7
manimal
manimal's Avatar
Do you have headers or stock manifolds, or Rams horns?
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 08-14-2012, 12:51 PM   #8
Firebirdjones
What are you working on exactly?
I've always found that the factory wire loom setups work fine for me, with or without headers. Depending on what you are working on most all of your factory wire loom holders are reproduced and they are relatively inexpensive.
Some route over the covers, some down the sides, some of your older trucks even ran under the manifolds and up the back of the block and bellhousing area and then come up the back of the cylinder heads by the distributor. (one of my personal favorites as they are almost completely out of site)
Firebirdjones is offline   Reply With Quote
Old 08-14-2012, 02:21 PM   #9
C25 Farm Truck
C25 Farm Truck's Avatar
Thanks for the idea, mongoose and exfordman! I just ran new wires last night and wanted a way to clean it up a little. I'm picking up some zipties on my way home tonight!
1985 C2500 3+3 Sierra Classic 454/TH400
Stock right down to the wheels, it's primary purpose is to haul cows.
It's secondary purpose is to provide me with many hours of fun and frustration.
C25 Farm Truck is offline   Reply With Quote
Old 08-14-2012, 06:17 PM   #10
BIGTEN
BIGTEN's Avatar
Jegs has them for 14.99 and come in many colors.
http://www.jegs.com/i/JEGS-Performan...rentProductId=
Old 08-14-2012, 07:40 PM   #11
slugish
Slugish
Thx All ,
Ive got headers bt the way manimal
Ive got these long T BOLTS that you screw into studs to hold valve covers down . Had a blue zip tie that actuall matches my plug wires .tried it looks ok to me
Will zip tie 2 plug wires to each of the 4 t bolts ( can get antwhere --made by Spectre) Also with the zip ties you can secure your wires where they are away from your headers& valve covers. Good idea.
Is there any better forum than this !!
Old 08-19-2012, 11:51 AM   #12
primrrd
primrrd's Avatar
i had seen a routing method with zips that used one inbetween each wire to separate them. hard to describe, but looked cool!
Found this link to demonstrate what im talking about:
http://www.circletrack.com/enginetec.../photo_21.html
here was a link in our forum that has some nice ideas on routing:
http://67-72chevytrucks.com/vboard/s....php?p=3306169
primrrd is offline   Reply With Quote
Old 08-19-2012, 12:07 PM   #13
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Wow, 4 little zip tie circles held together with a zip tie.....looks pretty good actually.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 08-19-2012, 12:57 PM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
If you want to clean up your motor get rid of the retro 80 T bolts. Heres how I routed mine...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-19-2012, 04:31 PM   #15
Firebirdjones
Yep, I mentioned earlier that GM had a factory routing system just like that where they ran along side the block and behind the cylinder heads. Was on the trucks mainly with the factory ram horn manifolds and you can still buy the reproduction brackets and holders to do it. Works great with headers too
Best factory plugwire setup in my opinion, keeps them out of sight.
Old 08-20-2012, 09:14 AM   #16
eldogg
eldogg's Avatar
You can route the under the headers using adel clamps if your headers have room or I like Taylor cable looms for above the headers. Check them out here. http://queencityspeed.blogspot.com/2...lug-wires.html
eldogg is offline   Reply With Quote
Old 08-20-2012, 01:45 PM   #17
88Jimmy4x4
88Jimmy4x4's Avatar
old corvettes were like that too, you can still buy the brackets
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 08-20-2012, 01:57 PM   #18
Firebirdjones
Yep, I used them recently on something else I was working on.
Old 08-20-2012, 04:37 PM   #19
boatpuller
boatpuller's Avatar
I used these and came around from behind the heads.You don't see much.I used red wires with a red dist cap.Look's cool Imo.I know you said you didn't wanna spend that much.I got a used set that look's new off ebay for under 20 clams.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 08-20-2012, 04:49 PM   #20
C-10 simplex
Not to be a pest, but i think we need to keep each wire at least .5 inch away from each other. Especially 5 and 7.
Elaborate.
C-10 simplex is offline   Reply With Quote
Old 08-20-2012, 05:18 PM   #21
bigwheel15
bigwheel15's Avatar
Elaborate.
Whats the reasoning behind that? Honest question
bigwheel15 is offline   Reply With Quote
Old 08-20-2012, 06:42 PM   #22
Firebirdjones
It used to be years back that racers would do this to reduce interference between cylinders. I'm not so sure it's an issue if you use a nice quality set of plug wires though.
