Old 08-13-2012, 08:46 PM   #1
biohazardbill
Rag Joint to U-Joint
There is a PS box on my 65, not factory, not sure what it is off of. The rag joint is broken. I will be putting in a different steering column soon. I thought about having the new column machined to fit a u-joint and figured I could replace the rag jount itself with a u joint there.
Doing some measuring it seems that the PS box has a 13/16 shaft so looking at some u-joints I see there are some 13/16 36 spline joints. Is that a common shaft/spline for a chevy PS box?
Also at the end of the shaft it appears there is a nipple that sticks out about a 1/2" id say. Would that interfere with the joint or should I grind that off?
Thanks in advance for any insight you provide.
biohazardbill is offline   Reply With Quote
Old 08-21-2012, 07:54 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Rag Joint to U-Joint
Do you have any pics of your steering box?
Keith
Convert to disc brakes.
Old 08-23-2012, 02:10 PM   #3
biohazardbill
I will grab a pic this afternoon. Are there markings or numbers too that may help?
Old 08-23-2012, 02:18 PM   #4
puppy
puppy's Avatar
Just did this mod on my 88. Grind off the nipple and slip on the u-joint. You will love it.
'11 Z71
'88 V-30 Crew Cab
'87 V-10
'69 Camaro SS
'52 M38
'46 Rat Rod
Word of the wise should be sufficient!
puppy is offline   Reply With Quote
Old 08-23-2012, 02:56 PM   #5
biohazardbill
Did you use a ujoint with a 13/16 36 spline on the PS side??
Old 08-23-2012, 03:14 PM   #6
puppy
puppy's Avatar
Mine required a 3/4"-30 spline.
'11 Z71
'88 V-30 Crew Cab
'87 V-10
'69 Camaro SS
'52 M38
'46 Rat Rod
