08-13-2012, 10:03 PM | #1 |
ECE Drop Spindle Problem
It's been a while since I've posted, but I ECE is close, and maybe someone's run into this before.
I ordered the 2.5 inch 3/4 to 1/2 ton conversion spindles a while back, along with the matching rotors, calipers and pads, bearings, etc. I've got everything together finally, but am having an issue with the brakes. The rotor doesn't seem to be on all the way, it's about .5 inches too far out, so I can't stick the outer brake pad into the caliper. I've got that nut torqued all the down to the end of threads, still not far enough. Anyone seen this before?
72 C20 http://www.houseofdewm.com Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=485286 |
08-13-2012, 10:11 PM | #2 |
Re: ECE Drop Spindle Problem
You know what, scratch that. I think I had a stroke of stupid.
I believe I shoved my rear end axle bearings into the rotor :| No wonder they were so hard to get in there.
08-14-2012, 12:43 PM | #3 |
bearing cap, not bearing, FYI. Don't do that :P
I swapped them out for the slimmer bearing cap, (I had everything in a box, and wasnt paying attention) and the rotor slid right on, got the outer bearing in, and the caliper with pads, all good.
08-14-2012, 04:05 PM | #4 |
Senior Moment
Dont you just hate when theat happens. Glad it all worked out for you. ECE is good stuff
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
08-14-2012, 04:08 PM | #5 |
dazed and confused
I know how you feel. Glad it worked out
members met: redbaron69, billsbowtie,nc67 |
08-14-2012, 07:16 PM | #6 |
where did you get the conversion kit?
08-14-2012, 09:40 PM | #7 | ||
"I ain't nobody, dork."
Umm... ECE?
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
08-27-2012, 10:15 AM | #8 |
here's a thread about them on the forums here,
http://67-72chevytrucks.com/vboard/s...d.php?t=360945
08-27-2012, 10:20 AM | #9 |
67-72 parts collector,…
