Old 05-23-2003, 10:28 AM   #1
Dandeluxe
Dandeluxe's Avatar
2 Inch Spring Drop On Front And 3 Inch In Rear
I HAVE ASKED THIS BEFORE? BUT I AM CONSIDERING BUYING 2 INCH DROP SPRINGS FOR THE FRONT OF MY TRUCK AND 3 INCH ON THE REAR. WILL I HAVE TO MODIFY ANYTHING IN ORDER TO DO THIS? EXAMPLE WILL I HAVE TO GET DIFFERENT SHOCKS OR ANY THING ELSE. I AM SUBMITTING A PIC. COULD SOMEBODY PHOTOSHOP THIS PIC. FOR ME SO I CAN SEE WHAT IT WILL LOOK LIKE WHEN I AM DONE WITH THE DROP. I AM GOING FOR AN EVEN STANCE ON THE FRONT AND REAR. THANKS, DAN
1969 cst swb 350/400 th . DANNY C .
["]FRIENDS DONT LET FRIENDS DRIVE F@RD$!!
1969 cst swb corvette hugger orange with 400 hp sbc
I started out with nothing and i held on to it
Dandeluxe is offline   Reply With Quote
Old 05-23-2003, 11:24 AM   #2
my new 72
faster, faster, faster
my new 72's Avatar
That looks to be more than a one inch rake to me man. New shocks are a must, but I would do the spindle swap up front over the springs. You'll keep a smotther ride if you do because you'll have more shock travel, but in the rear you should probably go 4 inches and relocate the shock mounts for the correct shock geometry to keep it a bit smoother in the rear too.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 05-23-2003, 11:36 AM   #3
Dandeluxe
Dandeluxe's Avatar
spring drop???
Josh, thanks for your input i am considering the spindle drop but it is so exspensive. i just put brand new stock early classic spindles for as disc. brake conversion. and i put all new stock springs on it. i am regretting it now . maybe i can sell all my stock parts they dont even have 500 miles on them. ill show you the look i am going for it is another members truck i hope he dont mind im using his truck as an example here goes this is the look im lookin for
Old 05-23-2003, 04:19 PM   #4
73stepside
73stepside's Avatar
i thinl the second picture you posted is a 4/6 drop. you can sell you used new parts on here. i'm sure someone will buy them from you. especially them being from early classics
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 05-23-2003, 05:21 PM   #5
'72 Shorty
I finally got an avatar
'72 Shorty's Avatar
I went 2-4 and didn't "have" to modify anything but the exhaust(fuel tank doesn' leave any room for pipes and axle there. I did relocate the rear shocks and had to get shorter ones to fit. I drove it for almost 2 months(Daily driver) after the drop but before the shocks and the ride is better with the relocation. it was quite tolerable to drive without moving the shocks though.
-72 C-10 short step (straight line only)
12.922/102.28
-69 C-20 on Propane (DD)
-69 C-10
-56 Mack B-753LS (tow rig)
-94 Chev K2500 Short Ex-Cab
-89 Isuzu Trooper...Kinda
-03 Kawasaki KFX-400
-05 Suzuki DRZ-400S
'72 Shorty is offline   Reply With Quote
Old 05-24-2003, 02:21 PM   #6
Dandeluxe
Dandeluxe's Avatar
2 4 DROP
THANKS FOR ALL THE INPUT . IF I CHANGE THE SPINDLES IM HOPING I DONT HAVE TO CHANGE THE NEW KYB GAS SHOCKS AND STOCK SPRINGS I JUST PUT ON IT ON THE FRONT? SO IF I GO WITH A 2-4 DROP ILL ONLY HAVE TO CHANGE TO A SHOCK RELOCATOR ON THE REAR AFTER I GO WITH 4 INCH DROP SPRINGS ON THE REAR ?
Old 05-25-2003, 04:29 AM   #7
73stepside
73stepside's Avatar
all you have to do is get the lowered spindles, shock relocator and and adjustable track bar.
04 GMC Sierra RCSS
70 CST LWB
Old 06-03-2003, 01:28 PM   #8
Gene
Gene's Avatar
2/3 drop springs up front, blocks and u-bolts in the back. Stock shocks no bottoming problem and the ride is excellent.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 06-03-2003, 10:46 PM   #9
70c10
67-72 Addict!
70c10's Avatar
Gene, you didn't use drop springs in the rear?. That looks great!!!!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
