![]() Join Date: Feb 2012
72 with turn signal problem
When I turn my head lights on my turn signals will barley turn on. During the day with lights off they work fine . Any ideas-maybe headlight switch?
Re: 72 with turn signal problem
Check your headlamp grounds. There are seperate points for the right and left headlamps.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
better than checking grounds is to disconnect and clean them up to bright shiney metal to metal contact when u reinstall them
I had just bought the truck after it had been sitting a year or better. The first thing was there was no ground from the firewall to the engine or battery to fender. After adding those it started working better. I will check the headlight grounds today.
Thanks, Wes |
