Old 08-14-2012, 12:27 AM   #1
jocko
jocko's Avatar
Never noticed this drip rail trim before....
Is this stock? Must be?? I've just never noticed it...
(btw, this is on a GORGEOUS C20 on ebay currently - full resto)
Old 08-14-2012, 12:48 AM   #2
DesertCat
DesertCat's Avatar
Re: Never noticed this drip rail trim before....
Back in the day you could get bulk trim that would snap on your drip rails from an auto paint store and/or JC Whitney. No clue if that is what is on this or not.
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 08-14-2012, 01:04 AM   #3
SS Tim
SS Tim's Avatar
Golden State sold a drip rail trim kit way back when (this is from'94). There is also a cancelled assembly drawing in my assembly manual, also from GSPP. :-)
SS Tim is offline   Reply With Quote
Old 08-14-2012, 01:04 AM   #4
leddzepp
Moderator
leddzepp's Avatar
i believe it was a factory option in 69. boardmember jeremiah king has a truck with this trim. from what i have read it is a pain to install which may explain why it was a short lived option.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 08-14-2012, 05:19 AM   #5
cdowns
cdowns's Avatar
yep factory option// yep a pain in the butt// near impossible to install without gouging out the paint
Old 08-14-2012, 06:35 AM   #6
72BLKCHEYENNE
72BLKCHEYENNE's Avatar
LMC has the option, I think it's $118.00 kind of a pain to install but it's cleans up the drip rail.........
72BLKCHEYENNE is offline   Reply With Quote
Old 08-14-2012, 06:54 AM   #7
Gene
Gene's Avatar
Found this set at a local salvage, no clue if it was factory or not, had my paint guy install it.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 08-14-2012, 09:33 AM   #8
Gene,that's truly a special touch. Looks great!
I have a complete set still packaged I've been hanging on to waiting for just the right truck. My '67 Super Custom may just be the one,if I decide to go with trim.
Old 08-14-2012, 05:15 PM   #9
Gene
Gene's Avatar
Thanks, I was truly surprised when I saw the truck with this trim, it was a Cheyenne but the glovebox was gone, I'm inclined to think it was factory because it wasn't riveted on like most aftermarket stuff I've seen and it was quality thick stainless steel trim.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 08-14-2012, 09:04 PM   #10
jocko
jocko's Avatar
Hmm. Thanks Guys! I never knew.
Old 08-14-2012, 09:40 PM   #11
71 super
71 super's Avatar
the common repair by the dealer was to rivet it on after it popped of. The last of the option was in 69 as stated because of the problems with it coming off. Jerry Brown of the truck shop in crossville used to install it on some of his trucks, his solution was to use a two part epoxy to hold in place rather than the interference fit and clips from the factory. For the record the instruction in the old golden state catalog are nice but the trim fits for crap and as cdowns said even following step by step very closely ended up repainting drip rails and trim wadded up in pile on floor
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 08-14-2012, 09:48 PM   #12
SS Tim
SS Tim's Avatar
Can anyone document these as factory? Are there any publications showing these as included with a trim option or as a stand alone RPO? The only things I have, as I said before, are the GMPP listing L150 @ $124.95(which would lead one to believe they originated it), an installation article reprint from Trucking magazine and a canceled drawing assembly manual page. Many GM options are seen in assembly manuals that did not end up being released for production. They have been out there longer than some of our member have been alive so it would no be a stretch for all seen to be aftermarket.
Old 08-14-2012, 10:29 PM   #13
Lee H
Lee H's Avatar
I think forum member Denz72 has this on his truck, maybe he can lend some info.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-14-2012, 11:29 PM   #14
chewychevy67
if you look on chipflyer's rpo list one says "B80 roof drip molding". i would assume if a truck had this it would be its own rpo but not certain.
chewychevy67 is offline   Reply With Quote
Old 08-15-2012, 12:29 AM   #15
SS Tim
SS Tim's Avatar
OK, maybe... but I was asking for a primary source. It is not in my '70 data book by that number or description. Chip's list is good but a lot of it applies to heavier other than the K5-C30s
Old 08-15-2012, 03:46 AM   #16
leddzepp
Moderator
leddzepp's Avatar
If the last of the option was '69, then it would not be listed in a '70 data book Does anyone have an earlier data book to see if there was an RPO code? The drip rail trim I have seen on the few original trucks I have come across was consistent with having been there well before the 90's and more likely from day one. I too am interested to see if it was a factory option listed on the SPID.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 08-15-2012, 08:25 AM   #17
I always thought it was a GM accessory. But,if it has an RPO code I am convinced it was a factory option. It's very unlikely that trim would be offered for medium/heavy duties that wasn't available for light trucks. If anything,it would be the opposite.Such as,a C/40-90 was available with Custom package and it stopped there. No CSTs,Cheyennes,Custom Deluxe,etc. And,even the Customs lacked features the light trucks had with that package. I never saw Golden State make anything that wasn't offered by GM,like LMC does. Seth was about recreated what was no longer available from GM...the originator of today's reproduction market on these trucks
