![]() Join Date: Jan 2002
Airline Routing
What is the best routing for the airline from the front bags. I have a couple of pushin bulkhead fittings that i could use through the crossmember but that is just more places to leak. I have never seen a compresion type bulkhead fitting.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
needs more $$$
Re: Airline Routing
I just drilled through the crossmember's spring pocket towards the rear and used a 90 PTC on the bag. Shoved a thick rubber grommet in there and called it good. For some added comfort, you can slide a piece of rubber hose over the air line where it goes through the hole. After that, it just runs down the frame rails.
1970 2wd Blazer |
Re: Airline Routing
They make them every day.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#4 | |
Re: Airline Routing
