Old 08-14-2012, 08:16 AM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Filler Neck Reroute
I really dont like the look of the gas tank filler neck hanging out of the side on my 72. Thinking about using a door like a newer truck, just not sure about the engineering behind the panel. Anybody that has converted post some pics please.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 08-14-2012, 08:29 AM   #2
Billett
Billett's Avatar
Re: Filler Neck Reroute
http://67-72chevytrucks.com/vboard/s...d.php?t=234732
or search for blazer tank installs. That's the best way to do it if you don't want the filler neck next to your door, otherwise you are running a ton of extra hose just to get back into the cab. And it would be at an upward angle so....
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 08-14-2012, 10:16 AM   #3
fxdxharley
Just a nother gear head
fxdxharley's Avatar
there has been several guys that put filler doors from newer trks. do a search in the projects and build section. if i remember a build I'll post a link for you. but its not to hard really, just need the donor panel section and weld it in to your qtr panel then fill original hole. then some ingenuity to route the hose.
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 08-14-2012, 10:20 AM   #4
fxdxharley
fxdxharley's Avatar
here is one Phat tony did behinde his side marker. go to post # 42
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
2013 HD FLHX
2000 harley fxdx
Old 08-14-2012, 10:22 AM   #5
Wasted Income
Boosted Member
Wasted Income's Avatar
You do realize that this is the "blazer/jimmy" section, right? He already has a blazer tank installed...in his blazer. lol.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 08-14-2012, 01:48 PM   #6
Billett
Billett's Avatar
Whoops I just clicked new posts and was trying to help out. Mornings aren't my thing as you can see haha well good luck anyway! I do recall a couple people cutting a section of their side out and using kitchen cabinet hinges to mount the fuel door but I don't have a linl
Will
2024 Toyota Sienna
Old 08-14-2012, 07:49 PM   #7
Wasted Income
Boosted Member
That's a cool idea. I wonder how they'd hold up to the constant vibration of automotive use.
Turbo diesel
Old 08-15-2012, 08:31 AM   #8
Billett
Billett's Avatar
Here it is, Post 59
http://67-72chevytrucks.com/vboard/s....php?p=4416828
Hart Rod did it. I don't know if you plan to use the side marker light, but the hinge could be used anywhere.
Will
2024 Toyota Sienna
