power window motor
i think need to replace window motor,looks like po cut about a 6 by 8 in. hole when motor was replaced before,if i remove the three bolts from regulator will motor come off,or i still need to remove the four bolts holding regulator to door panel?got 12 volts going to motor.thanks
Re: power window motor
Bolts should do it. make sure you test bench the motor.... The plugs and connectors normmal are the issue. good luck
thanks, i got both motors replaced.how i am replacing weatherstriping on windows and window vents.
