Old 08-14-2012, 08:10 PM   #1
66herbie
Parts truck
Have a 66 C10 250 3 on the tree. Want to do a t5 swap, found an s10 not to far away. Has anyone put s10 suspension/steering under their truck?
66herbie is offline   Reply With Quote
Old 08-14-2012, 08:40 PM   #2
rcbildr
rcbildr's Avatar
Re: Parts truck
I don't see why you would want to, that would be going a step or two backwards. The front crossmember & suspension from a 73-87 full size is almost a direct bolt on.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 08-14-2012, 08:47 PM   #3
joedoh
joedoh's Avatar
Re: Parts truck
I put an s10 everything under my truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=268337
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 08-14-2012, 09:45 PM   #4
66herbie
Re: Parts truck
Only reason it crossed my mind about the suspension was that I would like to swap the power steering from the s10 and get rid of the old "Armstrong" steering
Old 08-15-2012, 06:16 PM   #5
406 Q-ship
406 Q-ship's Avatar
Re: Parts truck
Depending on what year the S10 is, the brake are a joke and are not good enough for a 2800 lbs car let alone a 4000 lbs truck. You can use the suspension off a 73 and up C10, getting powersteering and disc brakes. S10 suspension is way to light for the bigger trucks.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 08-15-2012, 07:03 PM   #6
ljackson
ljackson's Avatar
Re: Parts truck
66herbie, have you seen this? http://67-72chevytrucks.com/vboard/s...d.php?t=367260
Lots of good info. We used the parts from an '81. Got power front brakes and steering
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 08-15-2012, 08:22 PM   #7
joedoh
joedoh's Avatar
Re: Parts truck
S10 trucks weighed 32-3300 lbs empty (nothing in the bed or the cab) and s10 blazers, with the same suspension, were 3900-4100. most of the weight in a c10 is in the drivetrain and frame, and most of the weight in an s10 is in crash protection and sound deadening. I havent scaled mine yet but I would bet a tenner it weighs less than the s10.
