how do you put the shaft in the control arms. do you screw on bushing in all the way and then the other.do you screw each bushing evenly.how do you center the shaft or do you have to center it. im not sure what to do.is there anyone out there who could give me some info on this.it would be appreciated.
Re: front control arms
Well I just took mine apart and I unscrewed both ends and then pulled the shaft so i would think you would put it together the same way, at least loosely and then when it is bolted to grossmember then tighten ends.
