08-14-2012, 10:25 PM | #1 |
Rusty Nuts
what do i check first
Well I got my cab on and wired everything up in the engine bay. My problem is it cranks over and and when I crank it will fire but when the key switch goes to the run position it will not run. So I am not getting power to the coil from the run side of the switch. So what do I check first. And is the key switch run wire directly to the coil .thanks for any help.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
08-15-2012, 06:19 AM | #2 |
Re: what do i check first
The run wire goes from the switch directly to the coil so your problem is in the wire or the switch. Since the engine runs with the starter engaged the wire from the starter solenod is intact. I am assuming that you still have the resistor wire in the run wiring so I would check that first as they are known to burn out.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
08-15-2012, 08:25 AM | #3 |
Rusty Nuts
Ok Thanks, I will ohm it out to see if its good or not then i will check the switch.
08-15-2012, 10:33 PM | #4 |
Rusty Nuts
Just to follow up, it was the plug connector at the switch. But also I noticed that I had 12 volts running through the resistor wire After i got a good connection so I went ahead and put a resistor block in and brought it back down to about 8 volts. Starts and runs good.
08-15-2012, 10:49 PM | #5 |
Nice work. Thanks for letting us know the results.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
08-16-2012, 09:29 AM | #6 |
Its a Truck Thing......
Are you running points or HEI?
Just curious.... Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time |
08-16-2012, 03:47 PM | #7 |
Rusty Nuts
I am running old school points and it purrs like a kitten.
08-16-2012, 03:57 PM | #8 |
Rusty Nuts
Here is a couple of pic of it so far, 1967 tilt, auto, power brakes 4x4
