![]() Join Date: Jun 2011
gas gauge problem
just got my truck back today from the shop. when i dropped it off it was out of gas on purpose because they had to remove my tank to weld. now the gauge reads pegged full all the time. any ideas what the problem is?
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
Re: gas gauge problem
Sounds as if the float is stuck in a upward position.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Mine works intermittently, when it is not working it slams to the right. I have not bothered to try and figure it out yet, but suspect it is a grounding issue. As your tank was removed and replaced, maybe grounding is your issue. Did anything else change at the same time?
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
Gauge wire or ground wire not connected?
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
Chevy addict
If the gauge reads full all the time, the sending unit needs to be grounded better or the sending unit is bad. If the gauge reads empty all the time the float is probably full of gas. Very seldom does the gauge itself go bad, usually sending unit or wire problems.
Take the wire off the sending unit, turn the key on and watch the gauge, touch the wire to a good ground, the gauge should read empty, take the wire off the ground, gauge should read full. |
