Old 05-23-2003, 02:34 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Which ball joints and rod ends
Does anyone have experience with Perfect Circle brand ball joints and tie rod ends? They are a heck of a lot less expensive than TRW and McQuay-Norris and for that reason I am afraid they are much cheaper in quality and not nearly as good.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 05-23-2003, 03:34 PM   #2
COBALT
COBALT's Avatar
I'm a Moog guy all the way. If you're running 3/4 ton like me then cheaper is NOT better. Just my opinion.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 05-24-2003, 12:49 PM   #3
BubbaGreen
Here is my opinion....
I favor MOOG as well. When I went looking for front end parts.
I found that the MOOG parts are made with all metal components.
Some of the less expensive parts have nylon inside of them. Only
good for a few thousand miles. IE, take the tie rods ends for
example, push the threaded part all the way to one side and look
down inside the pivot joint, the MOOG parts are all Metal. The
cheaper parts have nylon inserts down in there. As much trouble
as it is to replace the upper and lower ball joints, Go with the
best parts you can find....cheap tierods mean tire wear and lots
of alignments. Idler and pitman arms....equate to loose steering
when these wear. I have all the moog p/n's available for a '71 2wd
with p/s. Could have saved 50.00 or so, getting the parts from
summit, but i went to my local parts dealer, just incase something
didnt fit.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 05-24-2003, 08:32 PM   #4
mocwon
Keep On Truckin'
mocwon's Avatar
Thanks for the help...Moog it is
Just Passin' Thru
