Old 08-15-2012, 03:28 PM   #1
Howitzer
402 BBC Timing
Hey Y'all,
Sorry if this has already been posted on here.
Basically, I can't find the timing mark on my crankshaft gear. For this engine, is it the key slot?
Thanks.
Howitzer is offline   Reply With Quote
Old 08-15-2012, 06:22 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 402 BBC Timing
Is the engine in the truck completely built? You talkin' about the keyway on the crank snout? The timing mark in gonna be on the harmonic balancer. If it's not a new rebuild... it's prolly covered with oil and gunk.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-15-2012, 09:06 PM   #3
jtp67-72
jtp67-72's Avatar
Re: 402 BBC Timing
I think he's talking about the marks for cam timing.....should be a center punch mark on crank gear..if memory serves it does line with crank keyway...find the punch mark and put straight up..cam gear mark straight down with chain installed..bolt up......rotate engine till cam gear mark is on top and that is #1 tdc..stab distributor with rotor to #1...she will run......jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 08-15-2012, 09:33 PM   #4
Howitzer
Re: 402 BBC Timing
Yah, i'm talking about the cam shaft and crank shaft timing. I looked for the punch on the crankshaft gear for timing and i don't see one, that's why i wondered if it lines up with the key slot or not.
Old 08-15-2012, 10:15 PM   #5
jtp67-72
jtp67-72's Avatar
Re: 402 BBC Timing
went back and looked that up...put the keyway at the 2 o'clock position and look for an "o" up by the tooth that is on top..should be there...jim
Old 08-17-2012, 10:04 PM   #6
Howitzer
Re: 402 BBC Timing
Like so? I notice a couple of these screw type dimples.
Old 08-17-2012, 10:34 PM   #7
jtp67-72
jtp67-72's Avatar
Re: 402 BBC Timing
That's it...straight up like that...timing gear dot straight down in line with it...that puts cam in time with crank...rotate crank 360* with dot back up again and cam gear dot UP also...thats puts #1 tdc....install dist. with rotor facing #1 plug terminal...she will fire......Make sure u tighten cam gear before rotating crank.....jim
Old 08-18-2012, 12:24 AM   #8
70cst
70cst's Avatar
Re: 402 BBC Timing
Hey Howitzer ...
Just wanted to you and say from Ohio
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
