Old 08-15-2012, 06:40 PM   #1
chevy72pu
chevy72pu's Avatar
All covered up
Ok, so I am looking for some original valve covers with Chevrolet script on top of them. I am finding some of them available but they are not vented. My engine is a 350 with PCV and oil fill/breather in the valve covers. Did Chevy ever make any of these? Or can a set of the non vented kind be drilled and modified to accept pcv and breather? One pic shows the painted covers I want, the other is a pic of what I have now.
How 'Bout them Dawgs!
'10 Traverse LTZ
03 Silverado Z71 ext cab
99 Yamaha Grizzly 600
72 C10 350/350 sportside bed.
68 C30 flatbed. 350 4-speed.
"I've got a good memory, it's just short!"
chevy72pu is offline   Reply With Quote
Old 08-15-2012, 06:47 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: All covered up
You could drill a hole for a pcv grommet in the back of the cover towards the firewall to kind of hide the PCV. But you would still need a breather for the other cover.
The first engine you showed has the breather/oil fill tube in the front of the engine, and might even have a road draft tube coming out the back of the block... like in a 283 or a 327.
Gary
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-15-2012, 07:34 PM   #3
Rusbuilt
Rusbuilt's Avatar
Re: All covered up
I have a set that have been drilled for breathers and oil cap that I got from 67cheby. I'm not going to use them I may make a deal!
Rusbuilt is offline   Reply With Quote
Old 08-15-2012, 07:40 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: All covered up
Put the PCV fitting on the back of the cover...
LockDoc
Leon
Old 08-15-2012, 09:58 PM   #5
chevy72pu
chevy72pu's Avatar
Re: All covered up
I read somewhere that if you drill it for a pcv valve, you need to add a baffle to keep it from sucking oil in and burning it. Any ideas on that?
'10 Traverse LTZ
