Intermediate Shaft?
My 67 Shortie has a straight column (no tilt). Since it does not work well (no park). I asked around for a tilt and people tell me I need an intermediate shaft. Is this true? Or are people just trying to get another $50 for me?
Could I use an intermediate shaft from a newer truck? Possible a cheap junk yard part? Does it matter that I do not have power steering with a tilt column? Please post what you feel like answering. I guess 5 years ago when I bought my truck I should have spend more money on a truck with a V-8, power steering/brakes, and paint. But I am having soo much fun trying to piece my truck together. Jay.
67 Fleetside Shortie, small window, slip & slide tranny Upgrades--small block, tilt column, disc 5 lug conversion (front and rear), Future Projects--suburban gas tank under the bed, rear roll pan, better gas mileage (currently about 6-10 MPG) |
Resident Curmudgeon
![]() Join Date: Dec 1999
67/68 columns used a single long shaft that runs from steering wheel to steering box. In 69 they went to a shorter shaft and an "intermediate shaft". You will need one for a later year column be it tilt or not, but $50 is way too high IMO.
PS or manual, it's the same shaft. I doubt later years will work
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all Last edited by CPNE; 05-23-2003 at 03:31 PM. |
Thanks for the info. Maybe I will keep looking around. Junkyards here are picked clean for any good parts.
Jay
![]() Join Date: Mar 2003
The tilt columns are splined where as the older columns had what they call a double D with a thru bolt. Just put a tilt in my 68 and went thru the same prob.
