Old 08-15-2012, 09:54 PM   #1
ctouchet
ctouchet's Avatar
How hard is it to take the metal dash out?
i found a 1990 Chevy Blazer and the dash where the center AC vent was located was cut out to put a big radio in. How hard is ti to replace the metal part of the dashboard?
2012 F150 SuperCrew
2011 GMC 1500 (COMPANY TRUCK)
1982 Chevy Blazer 2WD (Work in Progress)
ctouchet is offline   Reply With Quote
Old 08-16-2012, 01:51 AM   #2
tobiahr
tobiahr's Avatar
Re: How hard is it to take the metal dash out?
good question, sub'd...any paint and body guys here know?
tobiahr is offline   Reply With Quote
Old 08-16-2012, 11:23 AM   #3
Jonboy
Slots go on anything!
The bottom unbolts, but it is spot welded all across the base of the windshield. If you didn't want to pull the windshield out of the donor, you could cut it close and make a flange out of the recieving vehicle. Pulling the windshield on the vehicle getting the dash would makie things a ton easier to weld up, though.
1974 Jimmy- 5.3/4L80e/NP241
Old 08-16-2012, 02:23 PM   #4
Keith Seymore
Keith Seymore's Avatar
So - basically, it's pretty tough.
Anything can be done (given enough time, money, talent and/or effort - pick no more than two) but this would be a lot of cutting and re-welding. Definitely not a "bolt in".
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-16-2012, 04:40 PM   #5
68Timber
I know the pieces fit
68Timber's Avatar
My factory "3 hole" radio mounting spot was cut for a modern DIN chassis radio. I bought an original uncut piece, but its only the approximately 8" by 10" around the radio. I plan to repair mine, cut out the bad and weld in the new piece. I can't weld for crap yet but have a friend that will do it for me. Can you repair yours that way?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 08-17-2012, 10:12 AM   #6
ctouchet
ctouchet's Avatar
Probably could, but the deal fell through, the guy that was selling it was a little shady so i decided not to buy it.
2012 F150 SuperCrew
