Old 08-15-2012, 10:07 PM   #1
hula
Is it ok if front and rear gear ratios are different?
I have a 1969 K20 4x4 I just changed the rear gears to 3:73 and the fronts have the old 4:56s. Does this mean I can't use the 4 WD with different ratios?
hula is offline   Reply With Quote
Old 08-15-2012, 10:15 PM   #2
69GWC
Re: Is it ok if front and rear gear ratios are different?
Correct don't use the 4wd untill you get matchng gear ratios.
69GWC is offline   Reply With Quote
Old 08-15-2012, 10:57 PM   #3
Redcap
You will have some serious problems if your front/rear ratios are different and you engage 4WD.
Redcap is offline   Reply With Quote
Old 08-16-2012, 12:45 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Those serious problems would include severe binding at the very least, and major parts breakage is a very real possibility. It would be undriveable.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-16-2012, 12:55 AM   #5
jayman68
Fun Stuff
jayman68's Avatar
You could go with different size tires front and rear. You would have to compute the circumference that would work with the different ratios. I don't know how to do this though. Otherwise don't use 4 wheel drive.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 08-16-2012, 12:57 AM   #6
71swb4x4
71swb4x4's Avatar
Breaking stuff may be the least of your worries. You will lose control and possibly wreck, hopefully just the truck and not you or someone else.
Change the front when you can. In the meantime don't use 4wd. You may want to pull the front drive shaft just to be safe.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-17-2012, 02:23 PM   #7
hula
What I thought. Front gears are next..
Old 08-18-2012, 05:17 PM   #8
wilkin250r
wilkin250r's Avatar
I think if you use 38 inch tires on the 3.73 axle, and 31 inch tires on the 4.56 axle you'd be okay
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 08-18-2012, 09:31 PM   #9
customisaak
customisaak's Avatar
^^^hahaha! maybe 38''s on the front but would that ever look dumb
80 k35 3+3 DD (big dirty)
85 k1500 DD (scottsdale)
and then a few more
customisaak is offline   Reply With Quote
