![]() Join Date: Aug 2004
Rear end swap help
Hey,
Gonna be picking up the 65 C-10 here this weekend. Whoo Hoo What is the popular 5 Lug rear end to get for our trucks? Thanks, Steve |
Re: Rear end swap help
Looks like once again the 73 and up seems to be a popular choice or going with the new 5 lug axl kit.
I believe later model axles are a tad wider which may cause complications depending on wheel choice etc. Then you have to weld on new perches etc. Moser axle makes axle shafts 5 lug for our trucks or you can take your old shafts to a machine shop and have them weld up and redrill the new pattern. Then you can just get new rotors for a 67-72 I think
http://67-72chevytrucks.com/vboard/s...light=lug+swap
This link should help you out. I plan to chsngr my truck over to 5 lug when I have time to get in the shop. |
This has the factory drum information for the swap.
http://67-72chevytrucks.com/vboard/s...d.php?t=530295 |
SIR
if your truck is a "fleetside" you will have to cut 1" out of the lip on the wheel opening.
66long low fleet http://community.webshots.com/user/LVNR66 |
#8 | |
Posted via Mobile Device |
