Old 08-16-2012, 05:34 AM   #1
hilljob26
hilljob26's Avatar
which lift kit ultimatly gives the best ride
with all the options out there, i am sure you guys have your favs and you have your not so fav...i want to get one with the best posible ride,,blazer will have a 5.3 and 35" tires if that helps
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 08-16-2012, 08:28 AM   #2
Re: which lift kit ultimatly gives the best ride
I like Tuff Country EZ-rides with Rancho 9000RSXs. The shocks are expensive,but are 9 position adjustable and I like that on a truck that is sometimes empty and sometimes loaded and/or towing. I only use all the way soft or all the way firm. I've had the same springs with Tuff Country's shocks on a truck I didn't tow with ('72 K/20) and did haul with some and it rode really well as well. If you move your spring mounts back and go with 56" rear springs you'll get an even better ride. The same for the front,to go with 52". On the front you'd go with 2" less lift because moving the mounts back gives you 2".
Old 08-16-2012, 11:09 AM   #3
Redcap
If you want a 'good ride', get a 2WD.
Redcap is offline   Reply With Quote
Old 08-16-2012, 12:32 PM   #4
69GWC
I have the Skyjacker Soft ride 2.5" lift springs and skyjacker shocks and my truck ride soo much better then it did, allmost as nice as my 06 Z71 does.
69GWC is offline   Reply With Quote
Old 08-16-2012, 01:08 PM   #5
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Tuff Country EZ-Rides. Best riding lift spring I have ever used.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 08-16-2012, 04:19 PM   #6
To me,a 4wd rides better than a 2wd. I don't need to ride on a cloud and the firmness of a solid axle/leaf spring 4wd beats the mushy dip and pitch of a 2wd in my book. There are leaf springs that give a much better ride than others and I think that's what Hilljob is asking about. He said "best ride",not "good ride" anyway
Old 08-16-2012, 04:30 PM   #7
Dunenutt
Newbee
Dunenutt's Avatar
I have always used Rancho springs and shocks, and have never had a ride issue. But I am cheap.
If you want the ultimate in leaf suspension, call these guys
http://www.deaverspring.com/
Hang on to your wallet, but worth every penny spent (If you got it).
Dunenutt is offline   Reply With Quote
Old 08-17-2012, 10:24 PM   #8
orbot
orbot's Avatar
skyjacker EZ rides nice and soft
orbot is offline   Reply With Quote
Old 08-18-2012, 08:30 AM   #9
I'd say any of the kits made that offer a softer/better ride will do ya. Basically,it's either the old school stiff kits or the one they offer for a softer ride/more flex. Some don't even offer that,so forget those. Kit to me means off the shelf package of parts to lift your truck. There are custom springs and also other mods for better ride/flex. Things like shackle-flips on the rear and using longer leafs by moving the mounts.
Old 08-22-2012, 10:04 PM   #10
29od1
I put a Skyjacker 2.5" lift on my Blazer and I'm very happy with the ride.
29od1 is offline   Reply With Quote
Old 08-23-2012, 09:20 AM   #11
Oilbrnr
Oilbrnr's Avatar
x2
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 08-28-2012, 11:02 AM   #12
DrDefunk
DrDefunk's Avatar
What shocks with the Skyjacker Soft ride 2.5" lift springs? they offer 2 different ones on the site.....
DrDefunk is offline   Reply With Quote
Old 08-28-2012, 12:00 PM   #13
CG
BlahBlahBlah
Welcome to the board DrDefunk. On the old black 4x4 I think I had Rancho 5000's, those rode pretty nicely.
And for those following this thread that know me ... DrDefunk is a very long time friend of mine (going on 40 years). He is the new owner of my green 72 K20 and he is already making it a much better ride. I think my trucks are happier when they leave me and go to new owners =)
Old 08-28-2012, 01:21 PM   #14
Welcome aboard Doc! If you've know this guy that long,I have a few questions about him maybe you can answer (#1:Has he always hung out with featherless rubber chickens?)
Old 08-31-2012, 01:56 PM   #15
DrDefunk
DrDefunk's Avatar
I think he used it's feathers to stuff his truck seat with.....
Old 08-31-2012, 08:27 PM   #16
69GWC
I know this I went with just blocks in the back and now my truck wheels hops like a ***** when you drop the hammer on it and it did not before. I will be buying rear spring to get my lift in the future.
Old 08-31-2012, 09:20 PM   #17
That feather bedding is nice until it gets all clumpy. That chicken rode in my truck and shivered the whole time.
Old 08-31-2012, 09:35 PM   #18
MTCK
MTCK's Avatar
As mentioned previously Tuff Country EZ rides are supposed to be the ticket. They have the lowest advertised spring rate of the major brands. Also greasable bushings help preserve smooth operation, and good shocks help. I'll let you know how the EZ rides in a 2" lift with some bilstein 5125's do in a couple weeks...
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 09-01-2012, 12:12 PM   #19
DrDefunk
DrDefunk's Avatar
Skyjacker Soft ride 2.5" lift - Tuff Country EZ rides 2" lift comparison,,,,,,,just what the good Dr ordered!
Old 09-01-2012, 12:19 PM   #20
DrDefunk
DrDefunk's Avatar
Now when I switch to automatic trans. I'll need a 700R4 vs. 4L60E comparison thread?? CG??
Old 09-01-2012, 01:24 PM   #21
CG
BlahBlahBlah
Just do a search here in the 4x4 section, or start a new thread asking the big question. Im pretty sure its been covered before though.
See ya sometime this weekend when you pick up more parts. Just give me a holler.
