![]() Join Date: Apr 2007
Before & then after.....what is this stuff??
Don't know if there has been a thread on this but I stumbled on this product by chance at Lowe's....then liked it so much just got 5 gallons....Evapo-rust...no acids..no alkalines....wash off with water!! 1st 2 pics are before...last 2 after only 2 HOURS!! ...U reuse until it doesn't work anymore...the little bit of black left will remove with a little scrub.....crazy stuff.....jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
Re: Before & then after.....what is this stuff??
That is pretty cool, where about in the store was it.? Might have to get some of that, does it say anything about keeping the treat from coming back or does it just remove it.
Posted via Mobile Device |
In the paint section where ospho is.....after washing with water...if not priming soon....u just redip and let it dry ....won't rerust...bought the 5 gallons from my local hardware guy..Lowes only has quarts....all sizes on Ebay.....u need to see what it does to a bucket of bolts!!....jim
![]() Join Date: Mar 2011
Wow!
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
How much did the 5 gallons run you?
![]() Join Date: Oct 2009
caramba. my last rust removal escapade almost resulted in the china syndrome. (muratic acid...) Good info!
Hmmmm, How could I dip my whole truck in this stuff?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
look on the label at the sizes available!! $85 for 5....On ebay the 5 gal comes dry and u add water...mine came all liquid from my local guy....Neat thing is U can pour this in different size and shape containers to cover oddball size parts....jim
THANK YOU for this thread with pix !! .
A buddy has been trying to get me to try it , now I will . Where in Los Angeles can I buy the 5 gallon pail please ? . TIA ,
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
Wonder if I could use that to flush the inside of my gas tank?
Thanks Jim! I have heard of this stuff but was very skeptical of course. Thanks for the pics. Now, to make a big enough dunk tank for my truck
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
Some vids on this on you tube...also a guy that did his Mopar subframe under car...sprayed it out of bottle..covered with a soaked towel...amazin finish with very little scrubbin'.....jim
#13 |
I'd be afraid I might not have a truck left
Rob 72 C/10 (under reconstruction)(destruction ? LOL) 48 Willys CJ2A 1952 Super "A" Farmall (Grandfather's) |
#14 |
![]() Join Date: Apr 2005
Cool stuff!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#15 |
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
#16 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
That stuff is neat I need to get me some it would save me so much time in front of the blast cabnet..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#17 |
FYI
Its available in most: advance auto parts, oreilies,autozone,etc. Using some on the roof of my truck now.
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
#18 |
Moderator
![]() Join Date: May 2007
A respirator and rubber gloves will prevent this.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#19 |
![]() Join Date: Mar 2010
This looks like a great product but....vinegar will do the same thing at a fraction of the cost. It might take a little longer but results are the same. I have tried a few parts using vinegar with good results. I like vinegar little more since it is in the garage where my kids and dog occasionally go. Not bashing the product but I actually read about the vinegar trick on this forum before.
1969 Chevy K20 Longbed |
#20 |
Looks like it's pretty safe too. Kind of unusual to get zero's across the board on the first line of the MSDS.
http://www.evaporust.com/docs/MSDS%20Evaporust.pdf I'll try it soon.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#21 | |
#22 |
1969 Custom 30 wrecker
I've tried this stuff & vinegar but my preference is something called Prep-n-etch. I get it at Home Depot for under $16 a gallon.
The nice thing is you mix it 50/50 with water so your getting 2 gallons for that price. This evaporust and similar products work ok the first time but IMO just don't last very long. Performance greatly drops on the second use and after that, it wasn't even worth bothering with. Vinegar is even worse. Worked great on first use but after that just about useless. (plus it stinks to high heaven!) The Prep-n-etch last and last and lasts. I just keep using over and over until it gets too scummy. Even then it still works! LOL
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
#23 |
Harbor Freight also carries it too but the smaller containers.
#24 | |
#25 |
just googled it...is phosphoric acid....jim
