Old 08-16-2012, 11:11 PM   #1
mexlokote
mexlokote's Avatar
fuel injection idea
I have an 82 Chevy custom deluxe 10, has original engine,
I have seen the fuel injection kits for sale for over 1k so today I found a 1990 Chevy blazer
With carb and fuel injection, so I thought if it would be possible to pull out the fuel injection parts and put them on my truck? If its possible how? And which parts?
mexlokote is offline   Reply With Quote
Old 08-16-2012, 11:41 PM   #2
WarBeard
WarBeard's Avatar
Re: fuel injection idea
Are you sure you are not looking at a throttle body?
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 08-16-2012, 11:54 PM   #3
mexlokote
mexlokote's Avatar
i am sure
Old 08-17-2012, 12:00 AM   #4
WarBeard
WarBeard's Avatar
How can it have both a carb and injection?
Old 08-17-2012, 12:03 AM   #5
mexlokote
mexlokote's Avatar
idk lol i just saw it didnt ger a chance to look close
Old 08-17-2012, 01:25 AM   #6
andrewmp6
Throttle body injection looks like a carb with injectors on it,It was used from 87 tell i believe 96 or 97 on the trucks.If you get the full set up it will work on your truck the other option is taking the tpi off a 3rd gen f body.
andrewmp6 is offline   Reply With Quote
Old 08-17-2012, 06:52 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
my 88 inside throttle body
maybe it's part propane
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 08-17-2012, 04:36 PM   #8
spencer_41188
spencer_41188's Avatar
gana be alot of parts and it only flows 500cfm
you will have to pull the top end heads and all the bolt pattern is diffrent then standerd/votec, wire harness, computer, fuel sending unit(or buy new), exhaust headers(or weld in bung for o2), distrubuter
these parts will add up at most junk yards if you can get a complet vortec engine with computer and wire harness. around here its 300 for an engine carb/tb to oil pan header to header and 50 for the computer and the wire harnes about 200 seeing its copper
you can put an inline pump, and filter but you will have to add a return line in some cases ... vortec will flow more cfm's its a better bang for your buck
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker.
spencer_41188 is offline   Reply With Quote
Old 08-17-2012, 06:18 PM   #9
mexlokote
mexlokote's Avatar
Well ill just keep my engine the way it is lol
