Old 08-17-2012, 12:11 AM   #1
late68
late68's Avatar
Is my flex plate on backwards?
I am having a bad feeling about this, and I think it is but I need some re-assurance. If so what are the issues? I have been having a starter problem!
1968 C10 SWB Dropped 5 in tha back 3 in tha front
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902
late68 is offline   Reply With Quote
Old 08-17-2012, 12:14 AM   #2
late68
late68's Avatar
Re: Is my flex plate on backwards?
Pics...
Old 08-17-2012, 12:25 AM   #3
jocko
jocko's Avatar
I'm afraid she's in backwards. I do believe the raised portion where you have the bolts going through - that raised portion should be on the torque converter side. This vid might help - take a look at time 00:40-00:50 to see what I mean.
Putting it in backwards will effectively move the ring gear of the flexplate aft - and by the witness marks on the ring gear from the starter, it would appear that's the case becuase it looks like it's only partially engaging on the forward edges of the teeth - assuming the starter solenoid is pushing the starter gear out the normal amount. Careful many more turnovers and you'll probably ruin the flex's ring gear. But, the real answer/tell-tale sign is the side that the indentations are on. Indented side of the flex bosses should face the engine, not the torque converter.
Sorry man, that stinks. Don't rip it apart til you get another opinion on here - but that's what it looks like to me.
Old 08-17-2012, 12:26 AM   #4
fakerwade
fakerwade's Avatar
sorry dude,,,epic fail!! (it's definitely on backwards)
Wade
JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!!
Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570
Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro
fakerwade is offline   Reply With Quote
Old 08-17-2012, 12:29 AM   #5
late68
late68's Avatar
GRRRRR!!! I knew it, I just didnt want to hear it! Back out with the tranny...
Old 08-17-2012, 12:41 AM   #6
Kerry P
It's not the best way but I have changed flexplates by just sliding the trans back a couple of inches on some vehicles. Sometimes a torque wrench won't fit so the bolts get torqued by feel with a box wrench. Like I said not the best method but...
Kerry P is offline   Reply With Quote
Old 08-17-2012, 01:00 AM   #7
Hotrob72
Hotrob72's Avatar
Really not that hard, swap out the top bolts for longer shoulder bolts, slide it back on the bolts and then flip the flex plate........yep, I did the same thing.
1971 chevy c10 ECE 4.5/6 dropped
1970 suburban ECE 4/6 Dropped 45K original miles so far
1948 Ford Sedan
1941 Dodge COE
1932 ford roadster
the rest are normal drivers
Hotrob72 is offline   Reply With Quote
Old 08-17-2012, 01:32 AM   #8
oklalawnboy
oklalawnboy's Avatar
That sucks, hope you didn't warp it.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 08-17-2012, 08:47 AM   #9
70CHEVYBB
70CHEVYBB's Avatar
For the cost I wold not reinstall it. buy a new one
70CHEVYBB is offline   Reply With Quote
Old 08-17-2012, 11:29 AM   #10
RenoKeene
Florida Edition
RenoKeene's Avatar
Yep, get a new one.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 08-17-2012, 11:35 AM   #11
late68
late68's Avatar
Yea looks like there about $60, so I will gran another one.
Old 08-17-2012, 11:45 AM   #12
mahanian
C10 addict
mahanian's Avatar
If the teeth on the flexplate are still in good shape I don't see why you would need a new one. Hopefully you weren't driving it like that, the torque converter isn't properly engaged inside the transmission and could cause issues.
Jared
67 C10 CST Short Fleet Big Window
65 C10 Custom Short Fleet Big Window
67 Camaro RS
mahanian is offline   Reply With Quote
Old 08-17-2012, 01:38 PM   #13
late68
late68's Avatar
No it hasnt been driven at all, only starter for about 45 seconds.
Old 08-17-2012, 01:43 PM   #14
KEL
72 GMC
KEL's Avatar
One learns by asking questions.
Why does he need a new flexplate if it was on backward for a short time ?
What causes the issue that makes it need to be replaced ?
KEL is offline   Reply With Quote
Old 08-17-2012, 06:05 PM   #15
WIDESIDE72
WIDESIDE72's Avatar
x2
WIDESIDE72 is offline   Reply With Quote
Old 08-17-2012, 06:08 PM   #16
WIDESIDE72
WIDESIDE72's Avatar
Even if the starter ate up the edge of the flex plate ring gear, it wouldnt matter after he puts the flywheel on 180 degrees (correctly) as the bad part would then be on the back side away from the starter. If anything it might have messed up the bendix gear. Even that is not tto expensive if you can find a mom and pop store to seel just the gear. Most chain stores look at you like you just got off a space ship when you ask for something like that!
